Rear Diffusers
Posted 07 December 2007 - 06:06 PM
Posted 07 December 2007 - 06:31 PM
Posted 07 December 2007 - 06:41 PM
Posted 08 December 2007 - 08:49 AM
Posted 08 December 2007 - 11:42 AM
Posted 08 December 2007 - 01:37 PM
Posted 08 December 2007 - 03:08 PM
One place I found some good info was http://www.ten-tenth...hlight=locost47
There were many other sites with good info on the actual physics behind how and why diffusers work and the other components that can aid or be aided by them or the opposite. (google "rear diffuser design")
After a few hours research I came to the conclusion that most designs for aftermarket road car diffusers are based on misunderstandings of how they and other aero dynamics work and their main advantages, or simple designed to look good with no regard for function.
If I were looking for an effective diffuser I wouldn't be looking at any of the premade items available for the vx, on the other hand if you just like diffusers then it simple, you buy whatever YOU think looks best.
Edited by Crabash, 08 December 2007 - 03:10 PM.
Posted 08 December 2007 - 05:59 PM
I guess the longer and deeper the veins the better. I have the Jimsan one which is probably somewhere between the out and out TMS ones and the more cosmetic TAT ones. It maybe in my head but I would definately say it's more stable at high speed. Was solid as a rock at 140mph on the Autobahn back in sept, was hunkering down nicely! Obviously it probably helps if you have the car lowered also as there is less air under the car then too!
Actually - exactly the opposite happens....
With a flat undertray and no diffuser fitted, the the lower the car is, the greater the effect of rear-end lift.
This is because the greater the effect is, of low pressure air flowing underneath the car (flowing faster than over the top), compared to high-pressure air over the top of the car.
The VX suffers badly from rear-end lift. Lowering the car without a diffuser will amplify the effect as you are increasing the effectiveness of the front splitter, as well as generating a higher flow rate of low-pressure air under the car. The VX is no different to the S1 and S2 Elise in that respect: Flat undertray leads to air passing more quickly under the car than over it. But, the air clings to the upswept clam, creating more turbulence at the rear, which results in lift.
The theory of fitting a diffuser is that you separate the lower pressure air from the rear of the car. If you do this, as speed increases you are actually creating small levels (less than 10KG's) of downforce, as opposed to lift. When you take this to it's extremes (as in F1 cars or sports cars eg LMP1's) then you can create significant levels of "free" downforce ie: that doesn't cost you straightline speed (vs wing-produced downforce, which obviously affects straight line speed)
My understanding from various comments, is that the S1/S2 and VX suffer from 30-50 KG's of rear-end lift at 120mph.
This is fine if you are driving along in a straight line with no compressions or crests but - take this onto the track - a place like the Nordschliefe, and there is potential for handling issues.
This was rather frighteningly demonstrated by a friend of mine on one of the 'ring trips we had this year. For those of you who know the 'ring, you will be familiar with "Lauda Kink" - it's a fast, very fast kink, which appears just after the half-way point (Breidscheid/Ex-Muhle) and is approached at about 120-130mph in my car. It takes big cahoona's to keep it ABSOLUTELY FLAT on turn-in and apex here. Most of the time I have a confidence lift on turn in then mash the throttle at the apex. I have taken it flat once or twice before but it was rather too close to the limit for my liking.
My friend (in a Honda Elise) lost it before the apex ie: the car went light on turn-in. Given the camber of the track at that point, it's a rather strange thing to happen. The car *should* be completely stable however, with an Exige from splitter it is estimated the front end produces crica 40 KG's of downforce. Now, with 40 KG's of lift at the rear, any aggressive change in the dynamic weight distribution of the car will accentuate this. The track was moist, in places but 95% dry. He did 3/4 360' spins and rather fortunately barely kissed the barrier, before coming to rest on the entry to Bergwerk, with all 4 tyres badly flat-spotted and a soiled pair of pants. He's now fitted a big feck-off wing to the car as well as a diffuser.
I also feel a similar effect over the crest just before Schwedenkreuz: approach at 140+ mph - take the crest dead straight on the right hand side on a trailing throttle and in theory you should land nice and firm. In the VX it's all a bit wibbly-wobbly. The extra lift at the rear causes the car to rotate...only by about 1-2 degrees but enough for the car following to notice that, as I was landing, I had rotated a little so I was *landing* on the sidewall of the OSR tyre - it flexing noticeably as the car settled itself. I can feel this in the car. Following an S1 closely over here at same speed, I witnessed the same - it's quite scary actually. Another car who was with us had a big wng on the back and it was totally planted on landing.
Back to diffusers <gulp> - the Thorney one will be the best for a track user as it extends the furthest from the back of the car and will elimintae all rear-end lift and probably give you some (a few kilo's) of downforce - not that you would notice the downforce. Unless you are going very quickly or racing, you will look like you reversed into Halfords if you fit one (no offence meant John).
There are various diffusers which match the same dimensions of those fitted to an S2 Exige - which has obviously been windtunnel tested by Lotus - so I would recommend purchasing one of those as they are [erfectly effective at eliminating rear-end lift and look perfectly stealthy on the back of the car.
I myself am waiting for Jimsan's next production run.
Sorry for the long answer but, I hope that explains the situation
Posted 08 December 2007 - 11:50 PM
EG Reverie http://www.reverie.l...rearwing_06.php
Anything less is just halfords tat*
*ps i have the jimsan diffuser, looks great
Posted 09 December 2007 - 02:20 PM
Not the case for the S2 shape.
The S1 has some downforce at the front, but (indeed) some lift at the back at speed. (this was after the re-design by the wintunnel guys as shown in the dicovery documentary, the original design was even worse.. Old shape audi-TT before they added the little spoiler on the back was also notorious for this issue..)
The S2 has a more 'equalized' setup where there is less downforce on the nose compared to the S1, but now also a small but measurable amount of donwforce at the back. This makes the S2 shape more predictable in it's response when speeds increase.
On the S1 a lot of the lift can be negated though by fitting the Sport160/111S 'spoiler' on the back. As the name implies is does not really generate any downforce, but it breaks up the airflow from the back of the clam to cut the generation of lift.
On the VX the body shape is quite different, but it's quite likely that the little 'winglet' on the VXT's serves the same purpose as the 111S spoiler and that is to reduce/negate the lift.
Diffusers only really generate any noticable downforce when you get the vertical panels very, very close to the road.. As in between 10 to 20mm or so.. Totally impractical for a road car.
In the same light as the small spoilers on the back of the car any iaftermarket/bigger diffuser may, however, help to reduce or cut the development of lift on the back of the car, making the car feel more stable at higher speeds.
Try getting hold of the book 'Competition car downforce' for an in-depth discussion on spoilers, wings (very different things!), diffusers, etc.
Posted 10 December 2007 - 08:53 AM
It the other way around the fast flowing air creates a high pressure region under the car and the curvature of the flow over the car created low pressure above it*, therefore generating lift as high pressure pushed towards low pressure. I'm not sure that lowering the car does actually increase the lift, but as you say it will significantly increase the front end downforce so upset the balance of the car at high speed.
* clicky for the proper explination of lift.
it is possible to get data, but it is expensive and the product producer has to be confident he will achieve cost/sale benfits
Hmm that is what we would term Gaffa Dazzel, while the Analysis may be valid it has no experimental results to back it up.
It also only considers the wing in a free stream of air and not when the air has just passed over a car, which is what makes designing diffusers so difficult as the whole car and the wake needs to be modelled to capture the effects.
Edited by Winstar, 10 December 2007 - 08:55 AM.
Posted 10 December 2007 - 11:15 AM
Posted 10 December 2007 - 11:53 AM
Posted 10 December 2007 - 12:39 PM
Slight misunderstanding - probably due to my wording
If you take the theory of "Ground-Effect" (pioneered by Colin Chapman)which we are discussing here, one of the main ways to achieve this is to design the flat panel undertry of a car so that incoming air from the front of the car, is accelerated through a narrow slot between the undertry and the ground. Ergo: the narrower the slot, the greater the acceleration of the air.
I was trying to say that, lowering the ride-height of a VX which does NOT have a diffuser fitted will greater accelerate air underneath the car, meaning it exits the rear of the car faster, thereby increasing the *effect* of rear-end lift (if you don't have a functioning diffuser fitted that is).
Posted 10 December 2007 - 01:01 PM
Front to rear angle of rake is important too in several areas. As eluded to above, length, AoA, end fences and leading edge , there is a lot more to it than that.
I did a lot of research on them and worked with the guys who do the aero effects for the Bentley le mans team.
Posted 10 December 2007 - 01:28 PM
Posted 11 December 2007 - 10:14 PM
Posted 11 December 2007 - 11:12 PM
Posted 11 December 2007 - 11:28 PM
I believe also that having the 2 undertray's join where the floor kinks up into the diffuser (if it is not a clean join)reduces the effiency and can cause the air to "break away" from the surface earlier limiting length and angle. (Sorry Jon I see now you already mentioned this)
Bernoulli's Principle is what dictates what happens under your car, if you want to understand it try here:
http://home.earthlin...19/venturi.html
Edited by Crabash, 11 December 2007 - 11:33 PM.
