Gaz Shocks. Setting Up
Posted 28 December 2007 - 11:09 AM
Posted 05 January 2008 - 10:43 AM
Posted 05 January 2008 - 10:54 AM
Posted 05 January 2008 - 02:17 PM
Posted 05 January 2008 - 05:49 PM
Posted 12 January 2008 - 12:02 PM
Edited by thelynxeffect, 12 January 2008 - 12:05 PM.
Posted 12 January 2008 - 12:07 PM
Bloody 'ell - I think mine is around 110mm, it must be low!I had set the spring compression ring so it sat 70mm from the bottom of the shock body. seemed like a good starting point, I'll see how it goes.
Can't wait to see the pics
Posted 12 January 2008 - 12:31 PM
to go with the coupepart I'm waiting for from B.A.D, then i'll post some.
Now that sounds nice!! Have been thinking about this for a while.
How much is it if you dont mind me asking? And will it have any vent holes like the exige cover?
Alex
Posted 12 January 2008 - 06:56 PM
500 euro's not including postage, no holes for vents, just cut your own. order one quick and i'll split postage cost with you!to go with the coupepart I'm waiting for from B.A.D, then i'll post some.
Alex
Posted 12 January 2008 - 07:03 PM
Posted 13 January 2008 - 11:19 AM
Posted 28 March 2008 - 08:37 AM
Posted 28 March 2008 - 09:04 AM
Just about to put mine on (outside and it's raining) wish me luck, thought I would put the spitfire bits on while I am there. I saw Techieboy was arround today so will keep him in mind if it all goes wrong as he lives not far
Nick, if you need some unskilled hands (or just someone to sit there looking like a spare part) for an hour or two, give me a shout.
Posted 28 March 2008 - 09:35 AM
This thread is perfect timing.
I was going to have a go at fitting mine over the weekend (weather permitting) - can you let me know how far you wind the black turney thing on the thread (technical description!
I've literally just come off the phone to Gaz and they recommended 10 clicks of the damper at the front and 20 at the back - does that sound right?
Finally, am I correct in thinking that the dial has to be at the top, rather than the bottom?
Edited by pincher, 28 March 2008 - 09:36 AM.
Posted 28 March 2008 - 10:04 AM
I was going to have a go at fitting mine over the weekend (weather permitting) - can you let me know how far you wind the black turney thing on the thread (technical description!) for the ride height and whether you are running a 16"/17" combo?
I have just come in to sort the ride height out , are people messuring to the wheel arch centre or underside somewhere on the body. I am measuring the hight left between the adjuster and top of the spring black turnet thing
SHOUT
Posted 28 March 2008 - 10:13 AM
Posted 28 March 2008 - 10:18 AM
Posted 28 March 2008 - 10:27 AM
Posted 28 March 2008 - 01:34 PM
Edited by NickB777, 28 March 2008 - 01:35 PM.
Posted 28 March 2008 - 02:06 PM
