Has Anyone Fitted An After Market Boost Controller
Posted 11 January 2008 - 05:13 PM
Posted 11 January 2008 - 06:26 PM
i was just thinking out loud,then you can set your boost to suit the driving conditions ie track road rain
How would you adjust the fuelling to suit to stop it running lean?
Posted 11 January 2008 - 07:06 PM
well lets just say you have a stage 3 running 1 bar of boost ,still run the same boost but with the after market controller you then got the option to turn it down say 0.8 or 0.7 so on still very safe and would realy affect the ruuning of the car just maybe abit richer and i am sure a good controller lets say a hks or blitz would hold a better level of boost as well,when i fitted a boost gauge to my car the boost came in at 1.2 bar the dropped off the 0.9 and was abit erratic
Edited by tony1, 11 January 2008 - 07:07 PM.
Posted 11 January 2008 - 07:17 PM
Posted 11 January 2008 - 07:22 PM
Posted 11 January 2008 - 07:49 PM
the stock ecu will fuel against sll levels of boost up to the maximum it's set for, you won't always be on boost so it has too
in principle just get a soft wastegate spring so it runs low boost and then run an aftermarket EBC and you can set any level from off up to the maximum it can fuel for
shouldn't be rocket science
ok well i will be ginni pig then i will fit one and then hook up the wideband lambda and see how it performs
wright off to get a boost controller
Edited by tony1, 11 January 2008 - 07:51 PM.
Posted 11 January 2008 - 08:02 PM
It will be interesting to see the results but I think it will overfuel if you reduce boost which could cause bore washing and driveability issues. I agree electronic boost controllers do control the boost better, and when properly set up you can have a faster rampup than a pnematic system without the overshoot. However, you really need to set them up when the car is mapped to make the most of them.
Good luck
Posted 11 January 2008 - 09:32 PM
Posted 12 January 2008 - 08:14 AM
Posted 12 January 2008 - 09:59 AM
Posted 12 January 2008 - 02:22 PM
Edited by Guy182, 12 January 2008 - 02:23 PM.
Posted 12 January 2008 - 02:27 PM
Generally my right foot copes with this reasonably well.i was just thinking out loud,then you can set your boost to suit the driving conditions ie track road rain
Posted 13 January 2008 - 09:43 PM
Edited by tony1, 13 January 2008 - 10:16 PM.
Posted 31 January 2008 - 03:21 PM
Posted 31 January 2008 - 03:23 PM
first of all, not sure what courtnay are talking about.
since when did courtenay reply on this thread?
did you sell an evc6?
Edited by Guy182, 31 January 2008 - 03:27 PM.
Posted 31 January 2008 - 03:31 PM
Posted 31 January 2008 - 03:42 PM
If so, the one you want is an HKS evc 6 (called the 5 in japan for some reason). It is stepper motor controlled, not solenoid.
Thats what we have.
Nice summary of how boost controllers work.
Posted 31 January 2008 - 04:16 PM
Doh, my apologies, I misquoted what I read you had written, must remember not to scan read, but trying to learn a new car as quickly as possible to decide if its for me.
I did sell an evc6 a few months back, I bought it and was convinced not to use it, as there were simpler quicker to install options that would meet my needs. I ended up with one of the inferior options I mentioned above (greddy profec B ) and in realising the issues it created (most notably on track) I rebought an evc6. This is sitting behind me in a box on the floor waiting to be installed on my evo to replace the greddy, but if I decide to jump into a vxt, it will be the first mod done to that.
Thorney,
Not sure if you are being sarcastic about my write up, but good to see you have a decent boost controller in there.
I don't think I'd bother with a separate gauge and the HKS does a good job of that.
do you fit knock sensors as a matter of course, or is that just a jap thing?
Some clever bod hacked the ecu in the states so mine flashes its check engine light if the knock count is high. was a £15 donation mod, but much neater than having another aftermarket unit adding mess and weight, not to mention cost.
Edited by Adam M, 31 January 2008 - 04:18 PM.
Posted 31 January 2008 - 04:26 PM
Thorney,
No, no sarcasm at all. We also tried a less sophistaicated controller and whilst it worked fine we thought we might as well go for 3d mapping on the car.
Posted 31 January 2008 - 08:45 PM
Thats what we have.
well i fitted the blitz sbc dual solenoid but still cant seem to nail a stable boost it tends to spike all the time ,but when it over boosts it still put the car into
limp mode and the car will not boost at all ,so the ecu can still control the turbo {it feels like it opens the dump valve}no engine check light came on because i did'nt disconnect the factory
controller,i also changed the actuator and still the same
Edited by tony1, 31 January 2008 - 08:47 PM.
