Use an Apexi boost controller on my black bullit: (not sure if I have all words translated correct)
VXT 4948 (registered 10/2004) Z20LER engine
GT2871 turbo, charge cooler
Vmax EVO400 software
Bigger oilpump, extra oilcooler, piston-bottom-oil sprayers
Stronger rods, performance pistons
Aggresive camshaft
High capacity fuel pump
Bigger fuel injectors
Steel flywheel
Removed balance-axes, Astra LEH groundplate incl. the oil absorber
Apexi Boost controller
Apexi airfilter, inlet airchannel 100/80mm, no air mass meter
Short belt altenator
70mm exhaust, 200-cell racecatalytic-convertor
Flowed cylinderhead, Natrium filled valves
Waterinjection, ERL programmable
This engine produces an incrible smooth 411 BHP. The boost controller does its job perfect. The only time I change the settings is for the yearly mandatory check where I reduce the boost from 1.85 back to 1.40
It comes with a nice graphical display where you can adjust boost pressure when your're driving.
Other mods on the car include:
Sachs raceclutch
Quafe LSD
Racelogic traction control, digital adjuster
Ohlins 2-ways
Steel brakelines
AP big brake, four-pot 308mm front, PAGID RS-15
Hi-spec, lightweight two-pot 320mm back. PAGID RS-42
Magnesium Speedlines satin-black 5-spoke
195/50R16 Yokohama A048R, 225/45R17 Yokohama A048R
4-point harnes, OMP Carbon steering wheel
VXR Alcantara seats
Blaupunkt navigation radio, Dension Ipod interface, IR controls
Scangauge-II, DriftBox and vehicle tracking system
Fire extinguisher (fixed tubing, electronic controlled)
No more seatbelt tensioners, no more airbag
Lotus Stack, 8000rpm
CF mirros, small internal mirror
CF roof 4,3kg , CF motorhood
CF rear wing, CF front splitter
GEL leightweight accu
BI-XENON, LED lamps
52 liter fueltank integrated catchtank
ABS can be switched off
Cruise control
And, most important, this is completely street-legal!
