Changing Turbo Engine Mounts
Posted 08 April 2008 - 06:58 AM
Posted 08 April 2008 - 07:27 AM
Posted 08 April 2008 - 11:58 AM
Posted 08 April 2008 - 01:45 PM
Posted 08 April 2008 - 03:53 PM
Posted 08 April 2008 - 05:29 PM
As long as you do one mount at a time there is no need to support the engine (there are another 3 holding it in place.)
on the NA you have to support the engine when dooing the off side mount other wise it drops and you can't get the bolts back in
Posted 08 April 2008 - 08:18 PM
Posted 09 April 2008 - 06:41 AM
Thanks for that. I did wonder why the new N/S mount was still loose after I had lowered the engine
Posted 28 May 2009 - 02:03 PM
Posted 29 May 2009 - 10:10 AM
Posted 29 May 2009 - 07:06 PM
They're engine mounts, pull the spanner hard then pull a little harder to tighten.
Torque wrench is reserved for engine jobs.
go slow and you can feel when the torque is right
Posted 29 May 2009 - 07:37 PM
Posted 12 July 2009 - 09:44 AM
Posted 12 July 2009 - 10:45 AM
Posted 12 July 2009 - 10:58 AM
Posted 12 July 2009 - 11:06 AM
Posted 12 July 2009 - 12:27 PM
Think I'll have to get one of them as I think the engine moves quite a bit under hard acceleration. Is the general consensus just to put the uprated bush in the front and leave the rear standard?
Thats what Courtenays said.
Posted 18 February 2010 - 05:39 PM
Posted 18 February 2010 - 09:08 PM
Has anybody got the picture instalation guide?
imho you REALLY dont need it... the description is accurate enough for even a beginner spanner moneky
Posted 18 February 2010 - 11:52 PM
Where did you buy them from Simba?I put the 'uprated' Powerflex mount on the front mount yesterday and after a drive this morning recon its one of best 'cheap' (£20) mods you can do to the car
More throttle response, car feels more alive, a little more vibration but not much - less than I expected, and 2nd gear shifts above 5k greatly improved!
Well worth the effort it tkaes longer to take the undertrays off and put them back on again than to do the fit mount!
