Egr Valve Cleaning/replacment
22 replies to this topic
#21 Muzzy
Muzzy
  • 433 posts
Posted 18 April 2008 - 12:21 PM
#22 Anarchy
Anarchy
  • 2,237 posts
Posted 18 April 2008 - 02:56 PM
Another tale of woe here
Order your cheater here
Get the blanking plate from Vauxhall or phone Autovaux and get it delivered.
You need a 13mm spanner or socket.
Remove the EGR valve, mount EGR valve using 1 of the bolts (sandwiching the plate) and turn the valve 90 degrees so the mechanism can still operate.
Like so...
Once you get the cheater get a mate to help if you are not confident. 10 minute job.
Instructions
What would happen if the EGR valve was fitted directly over the blanking plate? Does the valve try to plunge down into the plate, what effect will this have?
#23 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 18 April 2008 - 03:08 PM
The bottom of the valve is not flat. The plunger bit has a conical tip that sticks out by a few mm.
