Ap 4 Pots Big Brake Kit - Review.
Posted 22 April 2008 - 09:00 AM
Posted 22 April 2008 - 09:03 AM
Edited by Guy182, 22 April 2008 - 09:04 AM.
Posted 22 April 2008 - 09:28 AM
For road driving they were superb and I found the bite and stopping power of the 1144s really strong
I can only think the pads are the defining factor.
Posted 22 April 2008 - 09:40 AM
It could be the tyres I'm on (Hankook RS2s) but the stopping power doesn't feel as good as my original setup. I find it easier to lock the front wheels up - now this could be a combination of my bad braking technique and the increased power of the 4 pots meaning I shouldn't press so hard??
Isn't easier locking up of the fronts to be expected with the greater clamping force of the 4 pots and it's a case of learning to modulate your breaking?
I've got the same Plans setup as Subseamac and it's more than enough for me. Copes really well on all of the trackdays I've done and came in for a real hammering on the training day last Sunday. Not a hint of fade and they were taking some serious abuse on the tight circuit we were using. I really can't see me ever needing more stopping power than they provide.
Posted 22 April 2008 - 09:48 AM
Posted 22 April 2008 - 10:17 AM
Posted 22 April 2008 - 10:24 AM
Posted 22 April 2008 - 10:38 AM
Posted 22 April 2008 - 10:46 AM
Posted 22 April 2008 - 11:53 AM
Posted 22 April 2008 - 11:57 AM
On Sunday it was the first time I've ran my VXT on the track in anger (dust's himself down blows the cob webs off his lid) in its current set up.
AP Racing BB kit. (No front duct cooling)
Pagid RS14 pads all round.
Braided hoses, and race fluid.
Single Nitrons. (fast road set up)
Lotus Sport Adj ARB
16/17" OZ racing wheels
Toyo TR-1's
ABS disabled
One hour track session
Nice warm sunny day, corned beef sandwiches and pop (orange dilute)
Circuit Zolder - A real brake test circuit, three slow chicanes leading to and from fast sections.
Comments Brakes were ok for the full hour with a lot of abuse, no hint of fade only the tyres let go a few times under braking causing lock ups and a few hairy moments.
RS14's stood up well and once up to temp the braking zones were getting shorter by several metres. The VX's balance under braking was helped enourmously by the combination of Nitron/475 springs and a Lotus Sport ARB helped reduce dive under hard braking.
I ran with the Ferodo's and they were quickly replaced with the RS14's the transformation was like day and night.
Hope the above is useful.
Cheers
Ian
Danger 7,
Get those semi slicks on.
Posted 22 April 2008 - 12:11 PM
It’s great to hear genuine constructive comments on an expensive upgrade. I have been toying with upgrading to an AP 4pot BB setup for some time now. My current setup is Plans AP front discs, standard front & rear callipers with Pagid rs14’s all round.
I regularly stay on the track for up to an hour (yes I know ,not clever) & have no problems except that after 20mins of hard braking, the initial retardation is not as good, with a metal to metal sounding squeal when wiping big speeds off. In fact It feel like my rears sometimes seem to lock up, as the rear squirms around sometimes when full on braking at above 120mph, but neither the fronts or backs ever locks up fully!
It’s not really a complaint, but I just wish I could maintain the initial big reduction in speed on the first hard contact throughout the session.
I have had several conversations with Jon at Plans & he seems to think that he has a more suitable set of race pads that will be more to my expectations & that I probably would not see any noticeable improvement from my current setup if upgrading to the AP BB setup.
Personally, I would rather ditch 30-40 kg’s from my car and keep the brakes as they are now... That’s what I probably will do!
Max
With regards to the rear end squirming there's abit of info in my post in this thread that may be of some use. clicky
Posted 22 April 2008 - 01:23 PM
Posted 22 April 2008 - 03:24 PM
Posted 22 April 2008 - 03:54 PM
and create sparks.. lolre 1 hour sessions, Pagid do yellow (endurance) versions of the RS14. Might be an avenue to explore
If Performance friction pads are advised, I would urge caution. I have used them in the past and they chew through discs at an alarming rate and nicely deposit rusting disc deposits on the wheels and sides of the cars. Had PF97 on a clio cup before and swore never to use pf97 on any other car.
Posted 22 April 2008 - 04:19 PM
I was the same on EBC discs and 1155's but although we were going from flat out to hard braking without much in between, I wonder what our max speed was. I really have absolutely no idea as there just wasn't time to look. Was it more than 70mph? - was it on Ben's data logger? I guess it was a lot less than pulling up at the end of the Bedford main straight at 120+ mph. And although the brakes got a lot of abuse on Sunday without getting the chance to cool off, perhaps they weren't actually working that hard. Dunno, just a thought.came in for a real hammering on the training day last Sunday. Not a hint of fade and they were taking some serious abuse on the tight circuit we were using. I really can't see me ever needing more stopping power than they provide.
Edited by VIX, 22 April 2008 - 04:19 PM.
Posted 22 April 2008 - 05:59 PM
Posted 22 April 2008 - 08:33 PM
Your logic is faultless and something I hadn't thought about before buying
If you've already got most of the components it wouldn't cost you £1.5k to go to the 4 pots, probably under 1kExtremely useful feedback.
I like the look of 4 pots but I just couldn't bring myself round to spending another £1.5k just for looks on top of the perfectly good plans setup with 295mm ali belled ap discs. I even thought about keeping my discs but finding some 4 pot AP calipers to match the 295mm ap discs, but I don't think I'll bother as I'm totally happy with my setup
I think that braking efficiency is down to a combination of factors that all need to be right, including tyres (grip), suspension (dive+maintaining max tyre contact patch), pads and discs and finally calipers so maybe you need to have all other factors up to the standards of the AP 4 pot before you can notice any real difference?
For the guys who've got them and reported no big improvement, are you running r888/048, nitrons etc?
I'm running one way nitrons, 16/17" Hankook RS2s. I'll probably get even worse lock-up on 888s when I get them.
Any ideas:
How much is it to replace the AP discs for the BB kit?
How much are RS42s for the BB kit?
Posted 22 April 2008 - 09:44 PM
Posted 29 July 2008 - 10:19 PM
