Better Pedals For Heel And Toe.
118 replies to this topic
#21 TATONSPEEDY
TATONSPEEDY
  • 422 posts
  • Interests:Speedster, VX220, Lotus Elise, Lotus Exige, 340R, Catheram, Motorbikes, Mountain bikes, Computer, Web sites
Posted 25 May 2008 - 09:52 PM
you must have small feet !!! :P
OEM distance = 120 mm from the right border of brake pedal to center tunel
From Upper TAT brake pedal = 105 mm
From Lower TAT brake pedal = 115 mm
Hope this can help you to appreciate. At the top of your foot, its thiner.
It's just with my big feet (45 1/3 EU size / 10 1/2 UK) but enough.
Notice that at the lower corner, dimmensions is almost the same as OEM (115/120 mm).
#22 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 28 May 2008 - 06:25 AM
They look pretty good!! Are you replacing the whole pedal assembly, or just the ends? How much £$$£££$$£$£$£?? Can you do them in black?
#23 Mr_M
Mr_M
  • 946 posts
Posted 28 May 2008 - 06:50 AM
It's just the "plates" on the end of the pedals. Screw off the current ones, transfer the rubber 'dimples' to the new Tat ones, screw the Tat ones on. Job done.
Prices are:
Option 1 : Pedale d'accelerateur seule : 21E livrée [accelerator only]
Option 2 : Pédale d'accélérateur + frein : 30E livrées [accelerator & brake]
Option 3 : pédale d'accélérateur + frein + embrayage : 38E livrées [all 3 pedals]
make your mind up quickly - Thierry is taking payments now thumbsup
#24 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 28 May 2008 - 09:19 AM
Hopefully not too late to add to the list
List interrested :
Techieboy
Mr_M
Sutol
#25 Mr_M
Mr_M
  • 946 posts
Posted 28 May 2008 - 10:27 AM
List interrested :
Techieboy
Mr_M
Sutol
Should be fine, but I'd suggest dropping Thierry a quick PM to be sure thumbsup
#26 Sutol
Sutol
  • 8,122 posts
Posted 28 May 2008 - 10:42 AM
TATONSPEEDY you have PM
#27 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 28 May 2008 - 04:31 PM
bear in mind thats a VERY slim shoe - my work shoes are alot bigger than that (width wise) and catch on the brake pedal when coming of the accelerator as it is! :blush:
Do agree, H+T is not that easy...
Edited by cheeky_chops, 28 May 2008 - 04:31 PM.
#28 TATONSPEEDY
TATONSPEEDY
  • 422 posts
haaa... I was on bussiness trip, I'll try to answer to everybody. Thanks Mr M for you information but price shown was only for France delivery. I'll precise by PM for UK.
#29 TATONSPEEDY
TATONSPEEDY
  • 422 posts
Posted 28 May 2008 - 04:41 PM
In any case, As I saw it, I decided to reduce brake pedal optimisation to avoid any closing with center tunel.
So dim become :
From Upper TAT brake pedal = 115 mm
From Lower TAT brake pedal = 120 mm (As OEM)
#30 Mr_M
Mr_M
  • 946 posts
Posted 28 May 2008 - 05:43 PM
OK - no problem thumbsup
#31 subseamac
subseamac
  • 584 posts
Posted 29 May 2008 - 07:47 AM
I'm not so sure about the angled design. For my shoe size the best and only modification needed is a slightly wider accelerator pedal to move it about 1 cm nearer the brake pedal. I find the rest of the pedal layout perfect and would be concerned to use the proposed angled arrangement in anger - so to speak -
#32 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 31 May 2008 - 12:17 PM
Just an idea that might be usefull to anyone making a set themselves or designing a set for sale.
I just did mine with a pair of sparco pedals I had laid about from years ago, they are just the curved ally type (not cast) with rubber pimples in them therefore ideal for the VX, but the point is I found that my big feet tend to use the very top of the original pedal, so I moved the pedal up as well as it being a bit wider and offset sligtly to the left to reduce gap to the brake pedal which is also a little wider and taller than standard. Didn't bother with clutch, not doing it to look good.
Now I dont have to try and twist my knackered old knee and the pedal height suits my foot size much better.
These are what I used
http://www.sparcousa...dals.asp?id=351
Edited by Crabash, 31 May 2008 - 12:39 PM.
#33 TATONSPEEDY
TATONSPEEDY
  • 422 posts
Posted 31 May 2008 - 03:14 PM
definitive design of brake pedal :
From Upper TAT brake pedal to center tunel = 110 mm
From Lower TAT brake pedal to center tunel = 120 mm (As OEM)
#34 TATONSPEEDY
TATONSPEEDY
  • 422 posts
Posted 01 June 2008 - 12:02 PM
Due to still waiting for payment and necessary lead time for cutting and machining, pedals should be available for the end of June.
#35 covert ops
covert ops
  • 1,265 posts
Posted 03 June 2008 - 04:48 AM
List so far 03-06-08 Techieboy Mr_M Sutol Covert ops
#36 TATONSPEEDY
TATONSPEEDY
  • 422 posts
Posted 04 June 2008 - 04:22 PM
GB order in on way now ! Wait and see... :groupjump:
#37 Nikov
Nikov
  • 723 posts
Posted 05 June 2008 - 07:15 AM
Have I missed these? If not I'd like all three please. Cheers
#38 Nikov
Nikov
  • 723 posts
Posted 06 June 2008 - 10:38 AM
Cheers
Paid via paypal.
Cheers
ps does anyone know where the little rubber bullets are from, Lotus or Vaux?
#39 techieboy
Posted 06 June 2008 - 10:41 AM
If you find a source for them, can you let me know please? Some of them are looking distinctly worn on my car (61,000 miles) and I'd like to replace them as part of this upgrade.
Cheers,
Matt
#40 Sutol
Sutol
  • 8,122 posts
Posted 06 June 2008 - 05:06 PM
Cheers,
Matt
ditto - and also some of mine are missing, have you tried AutoVaux TB although i know theres no part no.
