Roof Seals - Lotus
37 replies to this topic
#21 Retset
Retset
  • 1,766 posts
Posted 17 June 2008 - 02:25 PM
I asked the guy at Sinclaire's today (in for geo and 10.9's) and he also said it was a PITA job and showed me just how much I'd have to be replacing. My interest waned somewhat at this point. He said that sticking back all the loose bit (top of screen) with sikaflex may well be what I really want to do ;)
#22 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 17 June 2008 - 06:02 PM
I've done that, but only lasts one winter - not so easy to do the next time...or the next etc :)
#23 Muncher
Muncher
  • 4,494 posts
Posted 17 June 2008 - 07:05 PM
I sikaflexed mine back on but after totally cleaning all the old stuff off, very thoroughly and preparing the surfaces. Touch wood it has been ok so far.
#24 Retset
Retset
  • 1,766 posts
Posted 18 June 2008 - 03:36 PM
Today Sinclaire's did the front drivers corner which was loose and covered in old araldite - they put some rubber stuff similar to sikaflex in. That will will do me for the moment on a garaged 2nd car. Couldn't help noticing the Nitrons whilst I was in the reception though :blush: :lol:
#25 M3VXT
M3VXT
  • 175 posts
Posted 20 October 2008 - 03:46 PM
Right then, here are the part numbers and prices (VAT to be added!)
Is this everything need for the front roof seal, door seals and rollbar seal?
#26 techieboy
Posted 20 October 2008 - 03:54 PM
Lotus rear/roll bar seal is too long. I fitted one a few weeks back and had to cut a section out from the centre of the rear seal (also too long at either end but it's no problem to trim either end). Still works perfectly well but was a bit disconcerting to have to get the sharp knife, cut it in half and remove a small section - just need to be very accurate to make sure the two halves butt together tightly.
#27 M3VXT
M3VXT
  • 175 posts
Posted 20 October 2008 - 03:57 PM
How can it be too long? I thought they used same soft top so how can the seal be a different length or am I just being thick :huh: probably being thick lol
#28 jazzyjeff
jazzyjeff
  • 2,391 posts
  • Interests:Many and varied of course
Posted 20 October 2008 - 04:09 PM
If those prices are excluding VAT and delivery, then including VAT it comes to £148.65 - more than £12 than the Autovaux price for VXT seals? Or am I missing something? :unsure:
JJ
#29 techieboy
Posted 20 October 2008 - 04:10 PM
Must be fractionally different - the hard top is. When you get the rear seal, there are two little bits that stick out and poke up underneath the B pillar trim just below the the hard/soft top mountig bracket. If you stick these bits into place and stick the seal down along it's natural path, it's fractionally too long and you get a bit in the middle that wont stick down. I just had to slice through it and shave a few mm off to get it to seat properly. Didn't even need any glue to fill the join as it was that tight, just put a small length of smaller rubber hose into the two hollow sections to join them (as is done where the rear seals meet the front seals towards the front of the door aperture). Tested it thoroughly and no leaks (at that point at least).
#30 techieboy
Posted 20 October 2008 - 04:13 PM
JJ
The front seal alone from VX was circa £150 when I got it from TMS. No idea what the rear seal cost (as I wrongly assumed it was all one part) so, then had to get the rear seal (which isn't on Mandarin's invoice).
#31 mandarinvx
mandarinvx
  • 12,621 posts
Posted 20 October 2008 - 06:08 PM
The total cost for the front seal set was £118 inc VAT, the bottom one on the list is a new wiper arm & blade :lol: In fairness for the £150 Vaux charge you only need the main seal (at the top of the list) - the cheater seals and secondary seals are additional items they've added to the revised setup on the newest Elises (also fitted under warraty if roof is leaking) I still haven't fitted the other parts, just the main seal, so prob no need for them unless leaks are really bad! - so in reality it's £76.06 compared to £150 :)
#32 Retset
Retset
  • 1,766 posts
Posted 21 October 2008 - 10:51 AM
Lotus got mine in after a week or so wait. Went for the main seal only after all the advice on here. £68 with a 10% SELOC discount thumbsup. In the cupboard waiting for lazybones me to fit it :blush:
#33 techieboy
Posted 21 October 2008 - 11:35 AM
Took me a year to summon up the courage to fit the front seal. Only did it because the old seal was in such a state that even sikaflex wouldn't rescue it. Was actually very easy to do, much to my surprise. :blush:
Edited by techieboy, 21 October 2008 - 11:36 AM.
#34 Retset
Retset
  • 1,766 posts
Posted 21 October 2008 - 04:09 PM
Hope so. Will have to sharpen my one and only chisel to remove some old araldite :blink:
#35 mandarinvx
mandarinvx
  • 12,621 posts
Posted 21 October 2008 - 05:08 PM
There are some pictures showing the differences between the seals whilst I was fitting it in this thread thumbsup
#36 gaffer1986
gaffer1986
  • 4,408 posts
Posted 02 February 2020 - 07:15 PM
Hi, I'm currently wanting to replace my front seal, do you still own the car and how has it held up? You said you used gunk near the cups, do you recommend using silkaflex also or just the provided double sided tape?
#37 myles
myles
    Sausagefest
  • 2,093 posts
Posted 02 February 2020 - 07:21 PM
Sikaflex is forbidden in this house after all the gunk that has been used on my car. Use tape.
#38 C8RKH
C8RKH
  • 804 posts
Posted 10 May 2020 - 02:27 PM
JJ
Holy thread resurrection I guess!  My windscreen screen is leaking (top of the A post and then dripping down both door windows onto the sill) and so have looked at the parts needed - looks like several have been upgraded but here is the list and new prices which now comes to £267.19 including postage from SJ Sportcars.  Anyone know if these will still work on the VX (as they have new part numbers/updates)
Description
Part Number
Unit
Unit Price
Quantity
Total
FRONT ROOF/DOOR SEAL ASSEMBLY
B116V0273F
EACH
£107.33
£107.33
L/H A POST CHEATER SEAL
C117U0133F
EACH
£30.16
£30.16
R/H A POST CHEATER SEAL
C117U0134F
EACH
£30.16
£30.16
SECONDARY DOOR SEAL (Front 600mm)
B117U0429V
EACH
£23.33
£46.66
Net Total
£214.31
Delivery charge - Delivery to United Kingdom (2.63Kg)
Estimated dispatch date: 15/05/2020
Show / Hide Delivery Options
£8.35
VAT at 20%
£44.53
Total to pay
£267.19
