Scared Stiffed
Posted 05 February 2004 - 11:47 PM
Posted 06 February 2004 - 08:54 AM
#3 Guest_skiddo (Guest)
Posted 06 February 2004 - 09:18 AM
Posted 06 February 2004 - 09:23 AM
What pressures are you running now?The car feels so much more secure/confidence inspiring/grippy now. Part of this is down to lower tyre pressures (apparantly they were over inflated and they prefer to run them at less than Vauxhalls recomendations).
Posted 06 February 2004 - 09:47 AM
Or £193 if your car's really buggered.How much?
Posted 06 February 2004 - 12:41 PM
#7 Guest_skiddo (Guest)
Posted 06 February 2004 - 12:51 PM
http://www.vx220.org...t=ST&f=2&t=5683
Posted 06 February 2004 - 01:06 PM
Posted 06 February 2004 - 01:12 PM
Posted 06 February 2004 - 01:59 PM
Jim, sharper and pointier does not always equate to more grip though, which I think is the effect Paul is referring to. Over-inflated tyres will give the impression of very direct steering when the tyre is square on the road, but the surface contact area drops off qucikly as soon as the geometry changes in bump or rebound or when winding on steering lock. A slightly softer tyre is a good compromise, maximising grip in all situations.Paul, I'd also be interested to know your tyre pressures, and what effect they say they have. I always felt mine felt a little sharper and more responsive when at the correct pressure, rather than a little below...
I usually set my tyres 3 to 4 psi lower than factory recommended settings when tracking, depending on the track of course. I could not get enough heat in the tyres at Cadwell Pk, so left them close to standard, but at Donington where the tyres are worked fairly hard I took 4 psi out. The tyres get a real pounding at Knockhill, and I have experimented with pressures below 20psi to begin with. makes for an interesting first lap until you get some heat in the tyres
Edited by garyk220, 06 February 2004 - 02:02 PM.
Posted 06 February 2004 - 02:14 PM
Posted 06 February 2004 - 02:53 PM
Posted 06 February 2004 - 03:51 PM
Posted 06 February 2004 - 04:36 PM
As for tyre pressures I think (talking from memory which isn't very reliable ) he said 22 on the front and 25 rear or there abouts.
Mine cost 150 = VAT but that was because l've lost my locking wheel nut key and he had to do it with the wheels on which is more dificult
Normally 120 + VAT
I guess thats 2/3 hours labour.
The settings are obviously different the standard Vauxhall/Lotus ones so I guess if tracking needs to be done then it will be back to them again.
Posted 06 February 2004 - 04:45 PM
I was running 26 / 30 at Anglesey as recommended in the handbook. I have decided I prefer them lower!As for tyre pressures I think (talking from memory which isn't very reliable ) he said 22 on the front and 25 rear or there abouts.
I had run 22/26 before and felt more comfortable with the handling & grip, so if there's no safety issue I'll go back to that.
Posted 06 February 2004 - 04:49 PM
Posted 06 February 2004 - 05:11 PM
Posted 06 February 2004 - 05:31 PM
Posted 06 February 2004 - 06:02 PM
nice one skiddo - cheers mate...you have the patience of a saint!foxy - many threads with details in but this is goodplace to start...
Posted 06 February 2004 - 07:32 PM
