if you can read this dodgy copy/paste from http://www.kentcams.com/index.htm then this is their cams for the 2.2 ecotec engine. they are quoting a power gain of 12hp if you search on their performance kits product search for the ec2001 sports injection cams.
anybody care to comment/have you tried any?
cheers
d
Product Search - Camshafts
Make Model Part Number Application Power Band Cam Lift Valve Lift Duration Timing Figures Valve Timing Valve Clearance
Vauxhall 1.8 2.0 2.2 16 Valve Ecotec EC2001 Sports Injection 2000-6500 10.16mm 10.16mm 256 Degrees 18/58 58/18 110/110 Degrees 0.00mm
Vauxhall 1.8 2.0 2.2 16 Valve Ecotec EC2002 Supersports 3000-7500 11.04mm 11.04mm 278 Degrees 31/67 67/31 108/108 Degrees 0.00mm
Cam Shafts
Started by
ddpunter
, Mar 17 2003 08:49 PM
1 reply to this topic
