Pre-cat
Posted 17 March 2003 - 09:24 PM
Posted 17 March 2003 - 10:00 PM
Yeah but they will have to go back on for the MOT, right?Well worth doing people! 3Hrs labour, a lifetime of pleasure!!
Posted 18 March 2003 - 12:32 PM
Posted 18 March 2003 - 12:51 PM
pre kat is there only for cold start emissions.Nah, the pre cat is not required for the MOT, (I am reliably informed by some long standing members!) It was put on so the car can pass Euro 4/5?? emissions regs in 2004ish. As the car is already sold it will not need to pass these levels.
Posted 02 April 2003 - 12:28 PM
Edited by TheRockstar, 02 April 2003 - 12:28 PM.
Posted 02 April 2003 - 02:27 PM
Posted 02 April 2003 - 02:38 PM
Posted 02 April 2003 - 02:44 PM
So you mean M6x30 bolts with a 13mm head?....and what do you mean by auto locking nuts?....(I assume you mean not 'Nyloc' nuts which are the ones with the blue plastic bit - not sure what other kind of self locking nuts there are...?.. )13 mm bolts about 30 mm long, around 6mm thread diameter with auto-locking nuts (not the plastic-ring kind!).
Agree with the idea Marco, a 'How To' section would be good..... Thorney, I'd be happy to pull this together if everyone sends me the details.....
ta
Nick
Edited by TheRockstar, 02 April 2003 - 02:45 PM.
Posted 02 April 2003 - 05:45 PM
Posted 02 April 2003 - 05:52 PM
Posted 02 April 2003 - 06:03 PM
ahh, thanks for the techie-english lesson....Nick,
Yep, the bolts are M6 x 30mm. The nuts are all metal self lockers, ie the very top of the nut is slightly crimped into a triangular shape.
"metal self lockers" is what I meant.... not triangular though , mine are just tighter et the end, with a softer metal edge that squeeze around the bolt....just finished using'em installing the backbox...got new steel bolts for the fecking "curve", by far the worst part to refit/adapt when installing a different exhaust...had to mod the clamp, and the heat shield
....after 3 curse-ful hours, now it's up at least....tomorrow morning I will tighten up everything, so that the bodyshells can be re-installed and painted anew....
#12 Guest_grand-fromage (Guest) (Guest)
Posted 08 April 2003 - 09:30 AM
Posted 09 April 2003 - 05:31 PM
Posted 10 April 2003 - 01:42 AM
Posted 10 April 2003 - 06:56 AM
..hint: if you are crap with mech. work, then don't even start it...
Edited by Ricky2772, 10 April 2003 - 06:57 AM.
Posted 10 April 2003 - 11:38 AM
Merci!http://www.vx220.org...f=9&t=597&st=15
Andy.
Posted 10 April 2003 - 12:54 PM
Posted 10 April 2003 - 01:50 PM
Posted 10 April 2003 - 02:38 PM
Posted 10 April 2003 - 02:55 PM
