Supercharger Performance
Posted 11 February 2004 - 12:14 AM
200bhp & 199ft/lb torque
0-60 = 4.2 seconds
Posted 11 February 2004 - 12:55 AM
Posted 11 February 2004 - 08:40 AM
Posted 11 February 2004 - 11:57 AM
Posted 11 February 2004 - 12:10 PM
Posted 11 February 2004 - 12:38 PM
Posted 11 February 2004 - 12:54 PM
Am I right in thinking that they had to work quite hard at lowering the PS level to get approval based on the Turbo's chassis homologation? If so may explain the modest performance claims.For their 200bhp supercharger on the N/A, Delta-Motor claim a fairly modest,
"less than 5.5 seconds"
As an aside, without changing the final drive on th N/A I imagine the acceleration figures for the supercharger would be better (though top speed obviously lower) than the turbo if they were the same power / torque roughly speaking?
Posted 11 February 2004 - 01:38 PM
Depends on the torque curves. I think the supercharged engine has a similar shape curve to the NA - ie. climbs rapidly to a peak around 4500rpm - with a healthy increase over the stock engine from above 3000rpm. The turbo engine torque peaks around 2500rpm and is pretty flat between 2000 and 5000rpm.As an aside, without changing the final drive on th N/A I imagine the acceleration figures for the supercharger would be better (though top speed obviously lower) than the turbo if they were the same power / torque roughly speaking?
0-60 and 0-100 times would be very similar if not slightly better since it's easy to keep the revs above 4500rpm, and the gearing would be shorter. In gear times at lower revs would suit the turbo engine better. All IMO of course
It looks like a great engine though. I'd certainly be getting one now if the turbo had not been produced.
Edited by garyk220, 11 February 2004 - 01:39 PM.
Posted 11 February 2004 - 01:41 PM
Williams fronts were last year, after 10 or 15 lapsFi don't use slicks anymore mate /pedant
Posted 11 February 2004 - 04:18 PM
280bhp & 290ft/lb torque
Posted 11 February 2004 - 04:28 PM
Posted 11 February 2004 - 05:20 PM
Yes, they told me that they had regularly seen 210 - 212bhp, one mech said 220bhp.Am I right in thinking that they had to work quite hard at lowering the PS level to get approval based on the Turbo's chassis homologation? If so may explain the modest performance claims.For their 200bhp supercharger on the N/A, Delta-Motor claim a fairly modest,
They started out by claiming 195bhp and now say 200bhp. As you correctly surmise, figures above 200 would cause aggro with getting official approval – and figures below it would be not v. good from a marketing point of view.
I think that, once installed and approved, it should be possible to fairly easily "find" a few more gee-gees people are apparently seeing 220 -230bhp without much extra modding.
Ricky's lightweight will probably be hitting 230+ at around 800Kgs – would be interesting to see it in action against a mega-turbo with around 280bhp but nearly 200 kilos more
Posted 11 February 2004 - 06:16 PM
But that is using flywheel power at the wheels so is over estimating. Remember that supercharger losses are already taken into account when measuring power at the wheels or flywheel - you can't double account.mahahahahha
Remember superchargers have an 5-8% mechanical loss of power as well.
That program needs some care. I got a fairly good rendition of my Audi TT but it took some playing with cdA and losses. I do not believe that Thorney's car will do 0-60 in 3.4. Nobles are about 3.8 and weight 10% more and offer another 20% more power
Posted 11 February 2004 - 07:40 PM
Actually mine weighs mine 860kg'swould be interesting to see it in action against a mega-turbo with around 280bhp but nearly 200 kilos more
Posted 11 February 2004 - 07:50 PM
Posted 11 February 2004 - 08:50 PM
Posted 11 February 2004 - 10:48 PM
Edited by P11 COV, 11 February 2004 - 10:48 PM.
Posted 11 February 2004 - 11:00 PM
Posted 11 February 2004 - 11:28 PM
