I was and still am a big fan of the Kumhos but have to say, my rears were dead after 4500 miles including 4 track days, so they died even quicker than my A039's. I have A039'S back on at the mo (fantastic tyre in all weathers, as I had 2 good fronts sitting in my shed) but will be putting Kumhos back on later.
I used 205 45's on the front and belive it gives sharper steering than the higher progile Kumhos used by some.
Have to say as an all rounder nothing comes close to the A039 in my experience but the Kumhos are a great buy that were as good as the original bridgstones, and probably better, which is no bad thing.
Martin s
These are the same fronts that we took off with the low speed understeer , last year ? It will be interesting to see if the old problem comes back as you have had several changes to the suspension and geo since.
The problem is comparing *any* worn tyres that imho tail off quite quickly when worn ( with many heat cycles and they will have gone a bit hard ) , to new fresh virgin squeeky rubber.
Judging by a dry track day to my eye , the A039 always looked like they were melting badly on track and the tread was rolling off.
Wait and see , on a cold winter day, the kumho's get up to working useful temperature very quick compared to the bridgestone re040 , and the R888s / A048 just don't have the tread block to generate any heat unless you can go quick enough around the corners.
I have overheard a few conversations at track days , road tyres are not like F1 slicks, they do not get better if you take them past the wear bars, you will just get unusual overheating problems on specific parts of the tread. I've made the same mistake myself when in a rush, forgetting to check tyre pressures going out , and when coming in.
The honest answer is there is no one tyre that does it all, but on the basis the semi slicks will last you a trackday season, then running a good all round wet cold capable tyre is your best bet. I decided that for this year I would not bother with the R888s , and have just replaced my Kumho rears after 13,000 , then did Silverstone GP circuit on Friday with 100 miles scrubbed rears and they were great.
Plus you will learn more on track with a grip limited setup , to use the ideal lines.
[edit] cost of rear KU31s last week was £68 fitted plus vat
Edited by siztenboots, 12 August 2008 - 09:10 AM.
