Coolant Change ...
Posted 22 August 2008 - 09:41 AM
Posted 22 August 2008 - 10:03 AM
Posted 22 August 2008 - 10:42 AM
Hi Guys
Has anyone here changed there own coolant before? If so could you possibly post a quick guide / the best way to do it ? Also does it matter what kind of coolant i use i was just going to buy the halfords advanced stuff ....
Cheers , Your help is much appreciated. Im sure its not hard but i just dont want any nasty surpises tonight haha
Sam
You will save if you get the stuff from vauxhall
Posted 22 August 2008 - 10:46 AM
Hi Guys
Sam
I bought 5L the other day for £13 ish, much cheaper the Halfrauds
Posted 22 August 2008 - 11:40 AM
Posted 22 August 2008 - 12:41 PM
Posted 22 August 2008 - 01:29 PM
Around 12 litres on the NA
This is the Vauxhall bleed method
OK so its going to be around the same, whats the normal mix method ? 2 parts water 1 part coolant ?
Cheers for the help fella
Posted 22 August 2008 - 01:30 PM
Have a look at the linkOK so its going to be around the same, whats the normal mix method ? 2 parts water 1 part coolant ?
Posted 22 August 2008 - 01:37 PM
50 50
Cheers for the help
Sam
Edited by Sambo1, 22 August 2008 - 01:37 PM.
Posted 22 August 2008 - 01:38 PM
Posted 23 August 2008 - 08:24 AM
Posted 23 August 2008 - 04:39 PM
Posted 23 August 2008 - 04:52 PM
didnt use that method when i did the rad just top up with six liter 50% distilled wate and 50% 10 years life antifreezeI doubt you'll need that much to be honest - there'll be loads left in the system
is it find even i cant drive it
Posted 24 August 2008 - 10:50 AM
Have done my coolant today after changing my rad, it took 6L, does that sound about right? I know the capacity is 12L, and 6L is quite a lot to be short. I have bled the system completely (i think) - exit pipe on rad gets hot and the rad area near the pipe, and eventualy the rad entry pipe gets hot when running. Left the car running for a while at 92 degres, but im wary of letting it run any longer or until the fan kicks in, as when the old rad blew i dont recall the fan actually coming on!
Does it all this sound normal?
Thanks
The whole rad should get hot, are you getting that?
Posted 24 August 2008 - 11:42 AM
Thanks
Yeah, after about 10mins or so running at approx 90 degres
Posted 24 August 2008 - 11:53 AM
Thanks
Run it through a full thermal cycle so the fan kicks on and off again - better to know its working in a controlled environment. Also this will push the temp past 100 and test the hose clips etc at full pressure. On an Na it comes on at 106.
Posted 24 August 2008 - 11:57 AM
Thanks
So it will get there at idle then if i leave it long enough? And if the fan does not kick in?
