Vx220 Turbo Alternator Poly V Belt A/c Idler Pulley
No replies to this topic
#1 daggles
daggles
  • 300 posts
Posted 25 October 2008 - 10:49 AM
This is the revised idler part no. 9318 3526 (£149+ VAT from Vauxhall) fitted to cars with a VIN of 7200 and later. The earlier version causes a slight miss-alignment of the belt, which cause the belt to squeak and extra wear on the belt (belt failure on the VXT can have dire consequences if you are unlucky). Reasonably easy DIY fit and uses your existing pulley and bearing.
Available on eBay Clicky
