20XE inlet cam with a vernier retarded half a tooth for good spooling
specifically this is what we are on about ,
http://www.vauxhall-...-mod-t1893.html
Posted 30 October 2008 - 01:50 PM
Posted 30 October 2008 - 02:56 PM
Posted 30 October 2008 - 04:39 PM
you would need oil temps north of 130c to see a high performance synth oil breakdown. Perhaps it is oil starvation thru long bends though i havent seen any reports(?)
Good luck with your choice
The oil temp on any modified VXT (stage 2 and above) will easily exceed 130 degrees after half a dozen laps.
Like others have said, fitting an oil temp gauge and oil radiator (ideally on a stat and fan assisted) should be mandatory for any average track use let alone frequent use in highly tuned cars
no way - there is a water cooled oil cooler already fitted (a air cooled one woulf be nice) - and if it was true, loads of people (inc me) would have a dead engine by now.
q1 have you ever measured your maximum oil temps?
q2 have you looked at the size of the oem water-cooled oil rad or even better it's spec vs a 13-row mocal cooler?
Posted 30 October 2008 - 06:25 PM
No and no.
Back to you - how many people on here (or AOC or ZLET or MIG) have had engine failure? Let alone traced back to oil temp?
Posted 30 October 2008 - 07:20 PM
No and no.
IME on MIG there has never been an oil temp related failiure with an XE or LET....
We have a few suspect engines at work that keep spinning big end shells when the oil gets hot but we have now managed to work it out that the temps go high AFTER the big ends failed
Posted 31 October 2008 - 08:34 AM
Posted 31 October 2008 - 08:55 AM
Posted 31 October 2008 - 09:25 AM
Posted 31 October 2008 - 09:57 AM
It's mainly down to the oil's ability not to shear at high temps. The sylkolene you use is one of the best oils out there with a HTHS of 5.11 and good fluidity even at low temps (which explains its price). I use Motul 300V at HTHS of approx 4.5, recommended by Opie oils as ok to run all day at 130 degrees. I may switch to silkolene next to try it out.
Most high performance oils need an HTHS of at least 3.7 to qualify, best to look for as high a HTHS as possible for the VX's as well as good low temp fluidity for winter cold starts
There are many people on here much better qualified than I am to talk about oils etc, I'm merely a "user" but I have always been particularly careful with engine cooling.
Posted 31 October 2008 - 11:16 AM
Posted 31 October 2008 - 11:50 AM
Posted 31 October 2008 - 04:28 PM
I use the Silkolene Pro S 10w50
Posted 31 October 2008 - 06:53 PM
To be honest firstly I'd find out what has failed and why. Whilst your dianosis maybe correct it is worth finding out what actually has happened. As for your assumption that 280bhp/ZLET on track is a short term combination I have to say I disagree, there is no reason why any high power VXT can't last so I would look to the cause rather than just assuming its your fault.
Posted 31 October 2008 - 07:04 PM
Posted 31 October 2008 - 08:01 PM
Posted 01 November 2008 - 08:07 PM
DohEngine & Gearbox sold
Posted 05 November 2008 - 09:36 PM
Posted 14 November 2008 - 12:34 PM
