Due to my supercharger conversion I will have the following for sale very shortly, amongst a few other bits which I would like to clear out.
2.4 inlet manifold + a set of ECU mounting brackets, hose and one way valve! (£135)
2.4 inlet manifold modified for fitment of 2.0SC TB + adapter plate + mounting brackets(£125)
This one has a slightly mis-shapen insert (pictured at the bottom) which you can either source a replacement or what I would do is just glue it in place. This manifold can be modified back for use with the standard throttle body by removing the screw and replacing with a brass insert that courtenay use.
Anti rattle door pins (£22 per set)
Vocky's aluminium inlet pipe (£60)
Only needs a K+N filter for the other end and according to vocky this was very effective.
Moonland hardtop (£450)
2.4 Manifold
Started by
Muncher
, Nov 02 2008 04:22 PM
No replies to this topic
