Full Change Of Light Bulb Options On Vx
30 replies to this topic
#1 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 07 January 2009 - 08:39 PM
Ended up going crazy on the light bulb side of things :D Techiboy its your fault I was happy with upgrading the dipped and side lights lol
So final spec is;
H1 (dipped) = HID 6000k -
http://cgi.ebay.co.u...em=290285836907
H7 (full beam) = Philips Xtreme power 80% brighter bulbs - http://www.lighting....s...ing&lang=en
http://www.carbulbsd...ail.asp?prod=81
PY21W (front indicators) = Philips silver vision - http://www.lighting....s...ing&lang=en
http://www.carbulbsd...ail.asp?prod=69
P21/5W (tail lamps) = Philips vision plus - http://www.lighting....s...ing&lang=en
http://www.carbulbsd...ail.asp?prod=79
T4W (front side lights) = Superlux 180 LED bulbs - http://cgi.ebay.co.u...em=220338936086
P21W (Reversing lamp & fog light bulbs) = Philips vision plus - http://www.carbulbsd...ail.asp?prod=83
W5W (side indicators) = Philips blue vision - http://www.lighting....s...ing&lang=en
http://www.carbulbsd...ail.asp?prod=31
Not changed the C5W (number plate lights) lol
Will keep the old bulbs as spares and total cost each inc P&P
H1 = £44
H7 = £29.35
PY21W = £13.45
P21W = £9.95
T4W = £9.94
P21/5W = £9.95
W5W = FREE (should be £9.95) free with orders over £10, so you know I got my friend to order 1 set of the bulbs over £10 so I have a spare set FREE again :D - credit crunch, got to save where you can lol
Total for all bubls on car exc number plate = £116.64
As per links either ebay or carbulbsdirect.com
Will post pics and a review after ;) not sure just how much difference the rear lights will make but will find out in 1 working day :D
Edited by Duncan VXR, 07 January 2009 - 08:40 PM.
#2 Yellow_or_black?
Yellow_or_black?
  • 12,905 posts
Posted 07 January 2009 - 08:47 PM
You forgot the courtesy light :rolleyes: :P Pretty impressive list!
#3 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 07 January 2009 - 08:52 PM
Bugger :D lol - might as well put a light in the boot also :D
#4 Yellow_or_black?
Yellow_or_black?
  • 12,905 posts
Posted 07 January 2009 - 08:57 PM
Well........I got the idea from Ouchie to stick two of those Osram (although there are other makes) LED, press on/off lights on the boot lid - one either side :) They're great thumbsup They come with velcro attachments, so you can just pull them off if you want to use them to look deeper into the boot, but the didn't hold - so I used the industrial velcro people use for number plates instead :)
#5 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 07 January 2009 - 11:58 PM
The new BMW 3 series has got LED number plate light bulbs which I think look quite cool.. ;)
#6 alanoo
alanoo
  • 1,324 posts
Posted 08 January 2009 - 09:28 AM
Can you use HID legally in UK without any MOT issue ? In France these are forbidden by the MOT-equivalent now, if not factory fitted with the HID washers
#7 techieboy
Posted 08 January 2009 - 09:33 AM
It's a bit of a grey area. If the HID lights are supplied as OEM, then the car needs washers and either self-levelling lights or self-levelling suspension. As an aftermarket fitment, there isn't currently anything law that makes them illegal to fit without the other bits. Government is trying to clamp down on them but no clear law yet. Certainly not had an MOT issues either with the VX lights, or the retrofitted HID's on my previous Audi (current one has OEM HID's).
#8 savvy
savvy
  • 2,524 posts
Posted 08 January 2009 - 09:36 AM
No problems with MoT as long as the light alignment is still correct you should be fine (technically they are illegal - a letter from Department of Transport confirmed it when asked by a member of the Type R forum wrote in and asked. Though, they did say there wasn't going to be an active persuit in chasing up there illegality)
That said, with non projector type headlights, when fitting aftermarket HIDs you can get a very erratic beam pattern - that would fail an MoT.
#9 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 08 January 2009 - 11:29 AM
Cant work out if you have too much money, time, sense... Or all of the above!!! ;) :D Any reason you didnt fit HID's to the full beams? Before after pics of these would be good :) edit: just ordered the sides...
Edited by cheeky_chops, 08 January 2009 - 11:31 AM.
#10 savvy
savvy
  • 2,524 posts
Posted 08 January 2009 - 11:39 AM
HID's for mainbeam are no good if you use them for flashing people as they take a few seconds to warm up
#11 techieboy
Posted 08 January 2009 - 11:45 AM
:yeahthat:
#12 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 08 January 2009 - 11:48 AM
:yeahthat:
#13 Retset
Retset
  • 1,766 posts
Posted 08 January 2009 - 12:29 PM
This is serious bulb commitment :D I had a headlamp bulb blow so went on ebay and got all 4 headlight bulbs as Osram Silver Star (I think .. +50% anyway) and Philips Blue Vision sidelights. The whole lot was £14 delivered. The headlights are now quite reasonable and the sidelights look bright white instead of dull yellow. All in all, good VFM. I'd recommend the sidelight bulbs to anybody - they were about £4. Edit: You can see them on in my sig pic.
Edited by Retset, 08 January 2009 - 12:29 PM.
#14 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 08 January 2009 - 01:58 PM
iirc Guy182 had them and posted they were no problem... :unsure:
#15 techieboy
Posted 08 January 2009 - 02:15 PM
It's not a "problem" if you're prepared to live with it. It's unlikely the few seconds it take to warm up to full intensity are going to kill you (they're not widowmakers after all) but my preference is for instant-on main beams. The best compromise for me was to fit the Philips Extreme Vision +80% bulbs, huge improvement over standard, good beam pattern from a standard reflector lens and they're either on or off.
#16 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 08 January 2009 - 02:28 PM
Paul, thinks it is all of the above :D:D:D - will def get pictures and give feedback
Have you ordered the front indicators Paul and got the sides free ;)
#17 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 08 January 2009 - 08:43 PM
Just bought some of these on offer on fleabay:
Edited by oblomov, 08 January 2009 - 08:49 PM.
#18 snoopstah
snoopstah
  • 3,056 posts
Posted 09 January 2009 - 09:41 AM
Is that for the front fogs - for some reason I thought they were an H-style fitment.
#19 Code Monkey
Code Monkey
    forum whore
  • 2,425 posts
Posted 09 January 2009 - 12:21 PM
I have also changed my rear sidelights/taillights for LED they go brighter faster and are brighter at all times, the only problem is that the high level brake light is always running at a very low level, less than braking brightness but something i can see will need to be sorted for mot time.
#20 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 09 January 2009 - 12:27 PM
Sorry should have made that clearer, that is the rear fog light. I dont have front fogs (brake cooling) so did not look them up :)
