Suspension Question / Problem
#101
Posted 26 March 2009 - 05:46 PM
#102
Posted 26 March 2009 - 07:51 PM
...get out and drive it
You're right but ... I'm too meticulous with this rare car, and it's not my daily.
That is strange then, as it must have only had std dampers on it all of its life
I must check if the bump stop is in good status
Edited by NeNeSs, 26 March 2009 - 07:55 PM.
#103
Posted 31 March 2009 - 01:38 PM
Edited by slindborg, 31 March 2009 - 01:44 PM.
#104
Posted 31 March 2009 - 01:47 PM
Rob and I went for a brief spin and the 325 up front and 475 rears seems to be a really sweet spot on his. I've got a set of 375's to fit to the front of mine to try.
@ GAZ customer service!!!!!
Especially the Gaz customer service part. Top stuff! And having 475 rears intstead of 375 has literally trasformed the car! So much better!
Overall, very pleased
#105
Posted 31 March 2009 - 01:52 PM
#106
Posted 31 March 2009 - 03:35 PM
#107
Posted 31 March 2009 - 04:21 PM
warren has got to be one of them rare people who will truely bend over backwards for you, i was very pleased with the communication i had from him.
just my 2p on the spring rates.
325F - 475R is what i had and i liked it, now i have 375F - 475R and i think im going to change back, or get stiffer rear springs.
have to ask again lol... did you wind the damping down a touch on the front dampers to suit the stiffer springs?
#108
Posted 31 March 2009 - 05:33 PM
I now have a 150lb split front to rear and it works well so can appreciate why you want to go back. You want about 525 on the rear I reckon. Don't reduce the front back to 325 because the Gaz work best with stiff springs and relatively soft damper settings.
#109
Posted 31 March 2009 - 06:13 PM
#110
Posted 31 March 2009 - 06:41 PM
slindborg - i dont know, phoenix fit them this time, ive not had them off to look.
retset - i agree with you 100% but atm i dont have £40 for some new springs.
wind the adjuster dial all the way to the - direction, then turn them the other way about 10-13 clicks. Then they "should" feel ok... if you dont like that then have a tweek of the dial.
Far cheaper (free) than paying to get the springs swapped back
