Axle Stands
42 replies to this topic
#1 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 12 April 2009 - 02:12 PM
Right then, I bought a pair of axle stands to use when replacing my Anti roll bar.
Now, I'm not sure how to use these, so I will risk sounding dumb and ask, rather than risk damaging the car.
I need to lift the front of the car for access. How do I do it?
Do I jack one side of the car up, and place one under the front axle that is raised, then lower the car and do the same on the other side...?
Seems like this will create alot of torsion across the car when I lower it with one corner raised like that...?
#2 A13X
A13X
  • 1,053 posts
Posted 12 April 2009 - 02:47 PM
Ive never done this either. But if i were to do it, i would do as you have described but do it in progressive steps. So jack one side half way and put axle stand under. Then jack other side up all the way putting axle stand in. Then jack the first side up all the way putting the axle stand back in after.
Edited by A13X, 12 April 2009 - 02:54 PM.
#3 robin
robin
  • 3,810 posts
Posted 12 April 2009 - 02:53 PM
i was thinking same so not a silly question conclusion i came to was to buy a cheap jack and have one on either side and jack whole front at same time, then put axel stands under.
#4 VIX
VIX
  • 9,497 posts
Posted 12 April 2009 - 03:53 PM
Search mate, this has definitely been covered before. thumbsup
#5 Jameshs
Jameshs
  • 3,511 posts
Posted 12 April 2009 - 03:54 PM
I jack from the side point and the put one under the front on the machined section. Then lower and repeat on the other side. No problems so far with that
#6 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 12 April 2009 - 04:05 PM
Machined section??
#7 slindborg
Posted 12 April 2009 - 04:56 PM
as in you leave one wheel up in the air?
twisted tub ahoy
#8 oblomov
oblomov
    oblomov
  • 3,875 posts
  • Interests:Mumblers
Posted 12 April 2009 - 05:25 PM
Personally I use two jacks. With the bonnet open I place a long spirit level across the open bonnet space and with a jack under the front end of each chassis beam I jack the car alternating between one side and the other in small increments watching the bubble on the spirit level to ensure the car stays as level as possible throughout the whole process to avoid twisting the chassis. When the car is high enough I place the axle stands under the chassis beams behind the jacks and remove the jacks by releasing in small alternate controlled increments.
#9 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 12 April 2009 - 06:49 PM
twisted tub ahoy
:rolleyes:
The tub requires 10000nm of pressure for it to flex 1 degree. Or about 7500lb/ft.
http://www.sandsmuse...cal/engalu.html
#10 snoopstah
snoopstah
  • 3,056 posts
Posted 12 April 2009 - 06:52 PM
I've wondered this as well. I've never used axle stands but have thought the same thing, it doesn't feel like a nice thing to do. But surely the loads on the chassis would be hugely higher just driving over a pothole than doing this. Indeed, as far as the chassis is concerned, isn't this basically the same as having one wheel on a kerb and the other wheels on the road?
#11 slindborg
Posted 12 April 2009 - 07:08 PM
twisted tub ahoy
:rolleyes:
I'll remain on the side of caution regardless.... esp as that testing can be as vauge as you like, I did a bit of torsional testing at uni and its amazing how easy it is to a) cock up the results and B) skew them and c) misrepresent the numbers (kinda like rolling roads lmao)
#12 simsy
simsy
  • 957 posts
    DOB is not real...
Posted 12 April 2009 - 09:08 PM
Do you know how much interlectual property Lotus (who designed and manufactured the VX) have?.. Lotus GP experience alone is on a par with the world's best.... so at Uni you got some sums wrong..... LOL.... You will not twist a chassis lifting the front with one jack..... Feck me.....
#13 slindborg
Posted 13 April 2009 - 05:42 AM
Feck me.....
never said it was on an elise/vx tub :P and I probably did get a few numbers wrong since bending a space frame wasnt really of much interest, but its plain to see that you can get HUGE torsional stiffness results if you measure very near where you clamp the chassis, and of course much lower numbers the further away from the clamp you go.
anyway why isnt it "recommended" practice to jack each corner on its own then :lol:
so the tub wont bend, its still probably not wise practice to do it a corner at a time
#14 VIX
VIX
  • 9,497 posts
Posted 13 April 2009 - 07:30 AM
interlectual
:lol:
#15 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 13 April 2009 - 07:41 AM
So are we saying the above method is ok....?
If so..... Where exactly do you put the axle stand? Again, might be a daft question, but I just want to be certain. Do you use the jacking points? Anybody got any pics..?
#16 John Faulkner
John Faulkner
  • 898 posts
Posted 13 April 2009 - 10:53 AM
Feck me.....
:yeahthat: X 1000
Jesus this forum makes me laugh sometimes
#17 The Batman
Posted 13 April 2009 - 10:56 AM
Feck me.....
:yeahthat: X 1000
if you are not laughing you are crying :lol:
#18 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 13 April 2009 - 12:37 PM
OK then, are we saying then that it is ok to jack the car up, then lower it onto ONE axle stand at the front, then jack the other side up, and lower onto a second axle stand....?
#19 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 13 April 2009 - 12:46 PM
:tumble:
#20 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 13 April 2009 - 01:06 PM
Hope the tub/chassis doesn't twist under the cars weight otherwise the handling would be affected
