Axle Stands
42 replies to this topic
#21 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 13 April 2009 - 01:16 PM
Well I wouldn't do it... ...But then I have two of the aluminium low profile jacks to play with :D
#22 John Faulkner
John Faulkner
  • 898 posts
Posted 14 April 2009 - 04:37 PM
OK then, are we saying then that it is ok to jack the car up, then lower it onto ONE axle stand at the front, then jack the other side up, and lower onto a second axle stand....?
YES
#23 robin
robin
  • 3,810 posts
Posted 14 April 2009 - 04:56 PM
do it the two jack way and then your be just fine.
#24 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 January 2010 - 11:26 AM
YES
The Seloc guide says to do it this way too
http://wiki.seloc.or...wishbone_bushes
I'm going for it!!! :)
#25 VIX
VIX
  • 9,497 posts
Posted 03 January 2010 - 12:02 PM
Does this method require the undertrays off to access the front jacking point? :unsure:
#26 robin
robin
  • 3,810 posts
Posted 03 January 2010 - 01:38 PM
best way i found to do this was to jack up one side and using three bricks place these under the jacking points with a peice of wood to protect underside and same on rear jacking point then do the same on other side with bricks at front and rear and all done easily. saves buying axle stands for all four corners and not having to lift car so heigh to work on.
#27 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 January 2010 - 06:22 PM
Procedure
1. Remove the front undertray.
:unsure: :lol:
#28 VIX
VIX
  • 9,497 posts
Posted 03 January 2010 - 06:56 PM
Procedure
:unsure: :lol:
Sorry, I'm much better when there's a picture! :P
#29 vocky
Posted 03 January 2010 - 07:15 PM
Procedure
:unsure: :lol:
only if you are planning on changing the front anti roll bar thumbsup
you certainly won't find any jacking points under the vx220 front undertray :closedeyes:
#30 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 January 2010 - 07:42 PM
Is this an extended allen key, or socket on a bar..?
#31 FLD
Posted 03 January 2010 - 07:48 PM
I jacked the entire front up on one jack. The front of the tub where the crashbox bonds on is a major bit of metal! Just put a plank across this, jack in the centre, put axle stands under the sides (on the same plank), then remove the jack. Just needs one jack, easy to do, no twisting etc. (no prepares for flaming)
#32 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 03 January 2010 - 08:37 PM
whats your IQ?
#33 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 January 2010 - 08:47 PM
whats your IQ?
Quite in ingenious idea actually to laterally bridge the front jacking points, thus negating the need for a second jack.
How did you get the car high enough to get it all under the car though...? Did you jack it up first :lol:
#34 FLD
Posted 03 January 2010 - 08:51 PM
whats your IQ?
Probably more than yours!
Still, its had 5 years to degrade since it was last measured.
It was probably up on 4 blocks when I did this. Thats my easy way of crawling under.
#35 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 03 January 2010 - 08:52 PM
Yeah, that's what I do. It does get a bit wobbly if you stand on the back corners of the tub though, since the front stands are so close together.
#36 Sutol
Sutol
  • 8,122 posts
Posted 03 January 2010 - 09:06 PM
whats your IQ?
Meant as a compliment but hey ho :rolleyes:
#37 techieboy
Posted 03 January 2010 - 10:00 PM
thumbsup thumbsup
Exactly what I did, although not on a plank but some really heavy duty timber (5"x3" or similar). Just drove mine up on to my home made ramps to get enough clearance to get the jack far enough under the front of the car.
#38 duigy
duigy
  • 28 posts
Posted 03 January 2010 - 10:33 PM
I need to lift the front of the car for access. How do I do it? I appreciate the approach angle is an issue but would ramps do the job?
#39 vocky
Posted 04 January 2010 - 11:37 AM
normal car ramps will probably damage the front clam, you need very shallow ramps to get some clearance so the jack can fit underneath. I personally just jack from the side, the front of a vx is so light and the chassis so strong thats all you need to do :closedeyes: ps: I chopped the front off Theo's old vx chassis, believe me it's damn solid and stronger than most cars I've seen :blink:
#40 FLD
Posted 04 January 2010 - 11:51 AM
whats your IQ?
Sorry, I was preparing to be had right up the wrong un' so was on the defensive. chinky chinky
