Headlamp Blanking Plugs
Posted 05 May 2009 - 02:09 PM
They are the ones behind the bulbs, and underneath, as shown on this picture:
Thanks,
Phil
Posted 05 May 2009 - 05:28 PM
Anyone got a scrap headlamp with the large rubber grommets in? Before you throw it away, sell me your grommets!
Thanks,
Phil
Might be able to get some made up. Looked at it as I need some but turns out to be a couple of quid each (near a fiver!). You interested if I manage to get some done? Can you remind me of the ID.
Posted 05 May 2009 - 05:36 PM
Posted 06 May 2009 - 11:07 AM
Posted 06 May 2009 - 11:35 AM
I could do with one if you find any / buy in bulk
Ditto...
Posted 06 May 2009 - 03:29 PM
Posted 06 May 2009 - 05:37 PM
Edited by pjohn151, 06 May 2009 - 05:38 PM.
Posted 06 May 2009 - 06:09 PM
Posted 07 May 2009 - 06:43 AM
Never knew about the seal (11 - 93185673 STRIP,SEALING,25 X 12.5MM X 8M,COVER,HEADLAMP,RH TRAFFIC) but kind of makes sense to stop it rubbing away at the clam, or the cover (10 - 93185671 RH/93185672 LH COVER,HEADLAMP,RH TRAFFIC). What does the cover do (apart from restrict access to the headlight unit)??? Looking at the diagram, it implies it fits into the clam, behind the mounting braket???
Phil
Posted 07 May 2009 - 08:53 AM
Posted 07 May 2009 - 09:33 AM
As my lights are going into a freshly painted clam, I thinks some protective foam tape would probably be a good idea, but not at £48! This stuff is slightly narrower (10mm) than the 1/2" vauxhall stuff.48 quid of that is for the foam seal round the sides
Foam tape
I'll be getting a roll, so if anyone else wants some, let me know, as I should have some left out of the 25 metres!
Phil
Edited by pjohn151, 07 May 2009 - 09:34 AM.
Posted 07 May 2009 - 12:44 PM
Posted 07 May 2009 - 03:59 PM
Posted 08 May 2009 - 03:35 PM
They are solid rubber and look the same both sides (blanking grommet), not hollowed out like the originals (semi blind), so you do get your monies worth of rubber!
Just to prove they fit:
I've PM'd all who expressed an interest and so don't have any spare, so if anyone else needs any, feel free to contact the company - their contact details are in the top photo, min order value of £30.
On another note, the tape also arrived today...
Phil
Edited because Photobox didn't want to play
Edited by pjohn151, 08 May 2009 - 04:26 PM.
