Anti Rattle Door Pins!
Started by
ChrisJazz22
, May 05 2009 06:13 PM
10 replies to this topic
Posted 05 May 2009 - 06:13 PM
plz pm if you have any or know where i can buy from....
chris
Posted 05 May 2009 - 06:23 PM
In the meantime, wrap a bit of duct tape around existing pins a few times. Not as pretty as shiney new pins but rattle free....!
Posted 06 May 2009 - 06:06 AM
Thanks guys!
Posted 06 May 2009 - 06:15 AM
To fit them, duct tape down all the washers around the base of the pin. Undo it nice and gently and re screw in the new ones.
Inside there is a captive nut that can drop back and stop the new bolt screwing in. If this happens, get a small piece of wire and make a small hook on the end. Use that to pull the captive nut back to where it should be and use a small amount of loctite glue to hold it in place then screw in the new bolts.
The reason I have written this is that until I did this job I had been told all sorts of horror stories but it really is simple and makes a big difference. Did mine in 20 minutes (I lost a captive bolt and had to pull it back and was very wary when starting), but did a freinds in 5 minutes Saturday.
Martin s
Posted 06 May 2009 - 02:39 PM
Cheers martin! apreciate that!
Posted 20 May 2009 - 08:49 AM
Done mine today.Passenger side is perfect (no rattles atall).....but Driver side I can't find a pin position where the door doesn't rattle
Something/ somewhere is due to go right 1st time surely
Edited by boghouse, 20 May 2009 - 08:50 AM.
Posted 20 May 2009 - 08:55 AM
PM Crabash.
He has loads are they are better and cheaper than the Elise parts ones.
Posted 20 May 2009 - 08:56 AM
oh and they usually come the next day.
Great service from a fellow vxer and supports the community
Posted 20 May 2009 - 08:59 AM
Messaged him ta....Will prob just change the problem side...as the result on the passy side is just great
Posted 20 May 2009 - 06:33 PM
Thanks for that JG.
I do have about 15 pairs left at £16 inc P+P.
I also inquired about getting more made should I run out, unfortunately the new quote is £22 each based on 50 pairs, I no longer have the buying power via work (redundancy) to get them made very cheap so when these are gone thats it I'm afraid.
PM's recieved.
Edited by Crabash, 20 May 2009 - 06:40 PM.
