Squeeling Supercharger
49 replies to this topic
#41 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 05 June 2009 - 07:20 PM
Can't remember exactly what way they adjusted it, sorry, but it was visibly out, and apart from a squeeking on start up for a few minutes its all quiet now. Martin s
#42 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 13 June 2009 - 06:34 AM
The squeeking on start up is terrible now, but once warm it goes. If I dont drive it for a couple of days its even worse, almost like something really needs oiling? Any ideas anyone, as it would be hard to show a garage as within a minute of starting up squeeking goes. Martin s
#43 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 13 June 2009 - 07:02 AM
Martin s
sale the supercharger and go itb"s with cams :D
hope you find a solution on this annoying problem
#44 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 13 June 2009 - 07:32 AM
Martin s
So let me get this right. BoT managed to reduce/irradicate the squeeking and now it's back again, is that right? Is the noise the same as when i drove your car? Has it got worse? My experience of noisy belts is when they are loose but i know that your belt is quite tight. I'm wondering if one of the pulleys is not completely aligned in the direction that the belt is meant to be rotating, if that makes sense :? ie it's not a case of moving a pulley in or out but more of rotational adjustment perpendicular to the rotation of the pulley. Incidently, where abouts is the belt getting damaged? Are you in today cos i'll pop down?
#45 vocky
Posted 13 June 2009 - 09:08 AM
it is a worn sc pulley on the sc you purchased
#46 VIX
VIX
  • 9,497 posts
Posted 13 June 2009 - 09:23 AM
I'd be very interested to know what has "changed" in the SC conversion process to cause this. I had one of the last conversions with the "old" belt (and have since had the mod). Touch wood, I have had no belt shredding and no squeeling. The next conversions which had belt problems were down to a change in belt spec (unbeknown to Courtenay). So what has changed for techieboy and MartinS to have squeeling and belt wear issues? :unsure:
#47 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 13 June 2009 - 03:03 PM
Since BOT aligned the pulleys the main squeeling (belt slipping at 3000 and up ) has gone, though I think it may still be lurking at 4500 up you just cant hear it clearly). I think this is something different as its only on start up. The car runs really well and there doesnt seem to be any sign of belt wear now, so its really just an annoyance rather than a big problem (I hope). I have a new tensioner here but BOT thought the original was fine, but may try that next. Am off to Abbeville this weekend so will be a bit of a test to see if the belt is ok. (I have a spare 1285 with me!) Martin s
#48 The Batman
Posted 13 June 2009 - 03:08 PM
this belt thing is getting a bit anoying! you do not need a special belt......... i am running the cheapest belt i could get at the moment and it shows no wear or tear and has done 1500 miles rant but martin i do hope you get it sorted and am interested to know what it is
#49 Shamone
Shamone
  • 372 posts
  • Interests:Cars-VX220- Focus ST-Mini Cooper S - Bikes-Honda Hornet - Skiing
Posted 14 June 2009 - 07:22 AM
It does seem very strange. I went from the original style pulley arrangement but after having belts break on a regular basis changed to the new pulley - first with a 1300 belt which was really loose, then to a 1275 which is really tight. Never had the belt slip under any circumstances. I know this may sound strange, but have you considered the bypass valve. Just thinking that under idle this valve should recycle the pressure created by the supercharger rather than build up when not needed. I can't help think it's something that's making the supercharger difficult to turn. Do you now anyone well enough to swap the supercharger as a test?
#50 The Batman
Posted 14 June 2009 - 10:53 AM
you can try swapping to use my supercharger but im not exactly around the corner :(
