Performance Figures For Supercharged Vs. Turbo
21 replies to this topic
#1 WazzaVX220
WazzaVX220
  • 306 posts
  • Interests:Great Music, Love, Friends, Holidays, Great Wine, Cars, Beautiful places to drive Cars!!!
Posted 19 June 2009 - 08:42 PM
All this talk about modifications........ Has anyone actually figured a Stage I/II supercharged car to 60 - 100 - Quarter mile? Would love to know!!!!!!!
#2 SteveA
SteveA
  • 9,159 posts
Posted 19 June 2009 - 09:03 PM
Did some tests on my Stg2 turbo using race chrono and a GPS device. 0-60 - 4.5 (I recon very low 4's would be possible if i could avoid the rev limit in 1st :blush: ) 0-100 -10.1 1/4 Mile 13.7 I'm not very good at the launch thing. Edit - 245 BHP BTW
Edited by SteveA, 19 June 2009 - 09:06 PM.
#3 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 19 June 2009 - 09:08 PM
I would be more interested in comparitive lap times bearing in mind the difference in weight between tubby and s/c.
#4 SteveA
SteveA
  • 9,159 posts
Posted 19 June 2009 - 09:11 PM
Race Chrono does lap timing comparisons so I will get some data at the national. Any SC owners with similar power are welcome to borrow the kit for comparison. I think the difference will be more down to driver than power or weight. Just FYI a stg2 SC N/A isn't a lot lighter than a stg2 turbo.
#5 WazzaVX220
WazzaVX220
  • 306 posts
Posted 19 June 2009 - 09:12 PM
Yes, lap times with the same professional driver would be interesting....... Just wondered if there was much difference in a straight line? Any Supercharged owners want to come forward with hard Data? I'm on your side!
#6 techieboy
Posted 19 June 2009 - 09:53 PM
Best lap at Abbeville in my old 180bhp NA was 1.8 seconds slower than my SC'd car a few months later according to my data logging. Hard to make a direct comparison as on the trackday when it was an NA I was running on 888's and the SC'd run was in the wet (or probably more like moist in Top Gear speak) on T1R's. I've only just run the car in after rebuilding the bottom end but I can safely I gave a TVR Griffith the fright of his life on the autoroute on the way back from Le Mans on Monday. Exceedingly childish but was very funny when I backed off and the TVR pulled up beside me with the driver mouthing WTF? I might try some mid-range measurements now RaceChrono has configurable performance timing. Never bothered with their 0-whatever times as I've got too much respect for the clutch and engine mounts.
#7 chris
chris
  • 524 posts
Posted 20 June 2009 - 03:34 AM
Normally, with a similar power, car with turbo engine is quicker than car with supercharged engine.
If you compare the curves of torque, you can see that the turbo curve is higher in the major part of the engine rev. range, so in acceleration there is a difference in favor of turbo engine ...
If you are not convinced, I have compared performances of VX220 turbo (270 HP) and Lotus cup (260 HP) found in two articles of a French magazine (Echappement)
Perfomances of the cars are measured with on board radar.
VX 220 turbo (270 HP - 420 N.m - 887 kg - two persons on board + 150 kg => 1037 kg)
0-200 km/h => 16,8 s
1000 m 23,7 s
Lotus cup (260 HP - 240 N.m - 920 kg - Driver alone + 75 kg => 995 kg )
0-200 km/h => 18,2 s
1000 m 23,9 s
The two cars have Yokohama AO48 LTS
During the runs of the VX220 the journalist didn't stress the car, when he had performed the starting.
But the car was able to save a few 1/10 s from 0-100 km/h
(at this date it was able of 4,5-4,6 s for 0-100 km/h, so you can substracted 3/10 s to the figures of the VX220)
Moreover you have to take into consideration that gearbox of VX220 have 5 speeds against 6 for the Lotus ...
:closedeyes:
Edited by chris, 20 June 2009 - 04:33 AM.
#8 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 20 June 2009 - 07:13 AM
At Abbeville recently Jimmy Jam and I had many occasions to compare performance. We both have cars with around 148 bhp, mines a supercharged stage 2 and Jimmies a tweaked VXR (sorry dont know exactly what hes had done). We were absolutely matched. Jimmies cars power comes in hard and fast when boost comes whereas mine is just like a loud electric car. He said that following me, he could my acceleraion was just seamless and that he would drop back then gain again as his boost come in, following I couldnt see much difference, but think that of the two the sc is the easier proposition to drive and may work better on track in the wet. In real terms, no difference, but both great. Martin s
#9 VIX
VIX
  • 9,497 posts
Posted 20 June 2009 - 07:58 AM
Martin, If you only got 148bhp I'd take it back to Courtenay! :lol:
#10 PaulCP
PaulCP
  • 6,066 posts
Posted 20 June 2009 - 10:46 AM
Martin s
It's always going to depend on which track you compare with due to gearing.
At Abbeville which i know well there are some corners that the VXR will take in 2nd which if you use 2nd in the SC car will cause you to hit the limiter too soon on the exit. 3 years ago ShinyAndy & i compared the differences on track and to take out driver ability swapped cars for a time.
Don't forget that the SC car will not suffer from lag like the turbo. Whilst lag wasn't as bad on the VXR as the std "T" the initial pick was still not a good as the SC car
Edited by PaulCP, 20 June 2009 - 10:49 AM.
#11 Guy182
Guy182
  • 4,459 posts
Posted 20 June 2009 - 11:12 AM
thing is the way they generate the power.. if you are talking max bhp figures being the same the turbo will have a lot more torque as it has to create that power figure at circa 5600rpm (iirc) whereas the s/c will be making its peak power figure at nearer 7000.. though after being out in a supercharged 2.2 on track, they seem alot more controllable and driveable the turbo is a great road car though with all that torque at your toes.
#12 XXX
XXX
    Invisible ex-VX owner
  • 4,471 posts
Posted 20 June 2009 - 11:25 AM
I didn't know they did a 1bhp supercharger....
#13 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 20 June 2009 - 12:42 PM
Oops, as you all gathered, I meant 248 bhp. I think vocky summed up the sc best when he said to me it will be just like driving a 3.3 na,and it is. Martin s
#14 WazzaVX220
WazzaVX220
  • 306 posts
Posted 21 June 2009 - 07:51 AM
Cool. :closedeyes:
#15 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 21 June 2009 - 10:39 AM
Cool.
:closedeyes:
Yeah, mine and Martins cars have identical power (mine is a stageII VXR with a few other extras under the hood :lol:).
There's a vid from Abbeville if you go straight to 2:58 you will see we drag race down the back straight, and there's simply nothing in it!
My accelleration gradient is steep but short, where Martins is less steep but long. Translates to much the same thing in real life. I do appreciate the extra torque you get with the turbo though (278lbs/ft).
Only thing that lets my car down is weight. She's a bit of a porker!
Edited by JimmyJamJerusalem, 21 June 2009 - 10:46 AM.
#16 WazzaVX220
WazzaVX220
  • 306 posts
Posted 21 June 2009 - 12:59 PM
FatAss. :P
#17 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 21 June 2009 - 04:59 PM
you could start by taking the hard top off :P
having pax rides in both I think I prefer the feel of the s/c (not sure I could cope with too many torques) but both are quick and great fun thumbsup
#18 The Batman
Posted 21 June 2009 - 05:01 PM
still waiting for the swap Mr White ;)
#19 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 22 June 2009 - 06:46 AM
Well come to a bloody track day then!! :lol:
#20 MAXR
MAXR
  • 2,719 posts
Posted 22 June 2009 - 04:45 PM
I've driven a stage 2+ tubby at Castle Coombe. It felt every bit as quick as my car but I still was lapping at least 3 seconds quicker in my S/C VX. But I just put that down to the fact that I drive my car more often. Also, my car's suspension, Geo & setup is very different, I found the tubby understeered more & the gearing was very different...It did sound sweet! I have also had several encounters on track with various tubbies including vxr's and stage 4's. In my opinion, the driver makes the biggest difference making comparisons tricky. If I was to buy another VX as a track car only, then I would still go for a S/C NA over a tubby.
