Sachs Suspension For Vx220
Posted 23 June 2009 - 08:50 AM
Posted 23 June 2009 - 09:06 AM
Posted 23 June 2009 - 09:16 AM
Edited by crazyfrog, 23 June 2009 - 09:37 AM.
Posted 23 June 2009 - 09:34 AM
Posted 23 June 2009 - 09:48 AM
Edited by SteveA, 23 June 2009 - 09:50 AM.
Posted 23 June 2009 - 12:42 PM
Fab, winding the top collar down will increase ride height, winding up will lower the car. The springs are stiffer than the bilstein setup so start by setting your sachs to be roughly the same length then experiment. Lowering a little at a time until you get the right ride height. Quicker if you can find a way to adjust the collar without taking the wheels off. There might be room above the wheel to fit a skinny arm in otherwise you may have to reach up between the wishbones - make sure the car is raised on a good jack!
Duh, stated the obviousThe height is the ride height, floor to chassis. I thought.
Try compressing the spring to 125mm
Posted 23 June 2009 - 01:10 PM
sorry first time i change the suspension myself after 7 years and bad time i learn more
just wanted to be 110% positif
now i am confident to do it myself
Posted 23 June 2009 - 01:34 PM
Posted 23 June 2009 - 01:42 PM
Fabrice.... Did they arrive today..?
Hope so.
As a starting point, just mount them as they are. They were set really low on my car, so they might be a good setting once mounted on yours. I included a c spanner for you to adjust them yourself. Any issues, giv me a shout.
yes they arrived today and not bad condition
the setting for the dampers are 1 to 20 am i right and the red knob start from 1 when its fully undown ??
one big issue jimmy
i cant pay for them because you a arse and wont give me the bank details to transfer the money asap
you must be my only creditor lol
pm me please ..............
Posted 23 June 2009 - 02:32 PM
Do sachs have the rebound adjuster at the bottom, under the lower spring collar?
Yes
Posted 23 June 2009 - 02:50 PM
Lol, Fab you really are crazy
They are currently set at a nice setting, so no need to worry too much!!!!
Will pm you now
Posted 23 June 2009 - 03:18 PM
Lol, Fab you really are crazy![]()
Will pm you now![]()
i am not crazy just want to pay my bill ...nothing is free in life
transferring gazillion dollars now
Posted 24 June 2009 - 08:58 AM
finnish at 10.30 and wasn't a easy job specially the front one with little access du to the brace bar
use plenty copper grease spay
i have measured from the front and rear bottom fiberglass arch and will need to check again after they bed in
geo booked this week as well
one little problem the car steering is vibrating lighty at 70 mph so i think i will need to rebalance them again as this set up is more direct
doe that look right ???
the tires rub a bit on the wheels arch on full cycle turning right .........
Edited by crazyfrog, 24 June 2009 - 09:05 AM.
Posted 24 June 2009 - 09:05 AM
Posted 24 June 2009 - 09:17 AM
did 117 driver side and 116/115 at the front
same version at the rear 127/125
i haven't seen any speed bump yet and that will give me a good reason to slow down
Edited by crazyfrog, 24 June 2009 - 09:19 AM.
Posted 24 June 2009 - 09:26 AM
Posted 24 June 2009 - 09:28 AM
Posted 24 June 2009 - 09:29 AM
bit in a rush this morning btw so i will let the boys do it when they do my full geo
Posted 24 June 2009 - 09:32 AM
Posted 24 June 2009 - 09:33 AM
seems a little low fab and ideally you want the measure from the chassis and not the fiberglass. I dont get any rubbing
You need to measure from the metal chassis further underneath the car but just about where your arrows are.
