Harrop Super Charger Group Buy
27 replies to this topic
#21 Tim F
Tim F
  • 311 posts
Posted 26 July 2009 - 04:24 PM
It would be interesting to see the breakdown in parts \ labour. I suspect it's the labour that's putting the price so high, but can't say for certain. T
#22 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 30 July 2009 - 05:08 PM
Around £250 more for a stage 2 conversion with Harrop (with ~100mm pulley to leave power below 250bhp) thumbsup :)
#23 mandarinvx
mandarinvx
  • 12,621 posts
Posted 01 August 2009 - 10:58 PM
Jon, I'll give you a call to talk through a couple more things early next week, then after that I should be on the list (if there is a list yet :unsure:)
#24 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 02 August 2009 - 06:31 AM
that stuff is needed for a supercharge kit unless you go stage 1.... look at courtenays website :)
Yes, but other than that what would be required? Without labour?
Not that I am likely to be able to do this group buy, but what I would be interested in knowing is an approximate cost for a 250hp Harrop system all in except for exhaust and pre-rad. In my case I would want the price for the bits without installation.
I am already planning to install pre-rad lines in my project while the fiberglass sills are off. ;) Has no one tried running them alongside the main rad pipes?
#25 ChazUwe
ChazUwe
  • 2,450 posts
  • Interests:Cars, Computers, Drinking and travelling about.
Posted 03 August 2009 - 07:01 AM
Hi Mandarin,
Is that what Jon has quoted you, also are there any other considerations. i.e. can it be restricted enough just by the pulley size or would there also be a need to reduce the rev limit or any other such measures? I am currently weighing up my options to get supercharged.....
Cheers,
C
#26 mandarinvx
mandarinvx
  • 12,621 posts
Posted 03 August 2009 - 06:37 PM
Hi Mandarin,
Cheers,
C
It is, the GM unit is surprisingly expensive to start with! Although I guess in reality there's not actually that much difference between them production wise, and no doubt Harrop don't have the same level of overheads to absorb as the GM / Eaton line (presumably GM sell on at a mark-up from Eaton :blink:)
That price difference may be subject to variations in exchange rate / GM pricing structure over time tho
#27 ChazUwe
ChazUwe
  • 2,450 posts
Posted 04 August 2009 - 08:32 AM
Hi Mandarin, Are you going for that setup then Imnotworthy ???? Thanks, Charlie
#28 mandarinvx
mandarinvx
  • 12,621 posts
Posted 04 August 2009 - 06:21 PM
Hi Mandarin,
Thanks,
Charlie
For that price difference I'd be mad not to!
I already have a decent spare head (ported / oversize valves / double valve springs), and a 2.5" Piper with 4-1 sat around doing nothing at the mo
So then just a case of rods and pistons and see what it makes with a smaller pulley (and pref balance delete so I can up the rev limit to ~8k :D)
