Under-tray Spacers
40 replies to this topic
#21 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 12 August 2009 - 11:32 AM
There will definately be less downforce at the rear at higher speeds without the rear diffuser fitted
#22 Nev
Posted 12 August 2009 - 02:07 PM
I am shocked and flabberghasted that MaxR still has his heater installed ! :gayfight:
#23 alanoo
alanoo
  • 1,324 posts
You mean "more lift" :rolleyes: honestly I won't track the car without undertrays... one bad gravel at wrong time and car/engine/loom could be dead they are here for protection too thumbsup
#24 vocky
Posted 12 August 2009 - 02:13 PM
there is NO heater in Max's vx thumbsup
#25 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 12 August 2009 - 09:26 PM
Sorry Imnotworthy I thought that was Max's on the z forum for a Harrop build
#26 vocky
Posted 12 August 2009 - 10:01 PM
it is, but the white hose is direct from the crashbox to the cabin, no heater box fitted thumbsup
#27 NickB787
NickB787
  • 7,813 posts
Posted 18 August 2009 - 08:48 AM
Put the rubber spacers on, they are only 25mm but they seem fine. Now I can remove the undertray and work on the car and leave the spacers in position, a lot quicker also only cost £2.00 each :D [attachment=21338:CIMG2101.JPG]
Edited by NickB777, 18 August 2009 - 09:04 AM.
#28 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 18 August 2009 - 10:52 AM
Good stuff thumbsup
#29 Jameshs
Jameshs
  • 3,511 posts
Posted 18 August 2009 - 11:31 AM
Put the rubber spacers on, they are only 25mm but they seem fine. Now I can remove the undertray and work on the car and leave the spacers in position, a lot quicker also only cost �2.00 each :D
anymore pictures?
#30 VIX
VIX
  • 9,497 posts
Posted 18 August 2009 - 03:34 PM
I must have missed the bit about rubber spacers. I presume they won't melt, it does get kinda hot down there ... :unsure:
#31 NickB787
NickB787
  • 7,813 posts
Posted 18 August 2009 - 04:47 PM
[attachment=21340:CIMG2103.JPG] Not in any direct contact with anything hot so should be OK
#32 NickB787
NickB787
  • 7,813 posts
Posted 18 August 2009 - 04:54 PM
I used covered nuts to stop the threads rusting
Edited by NickB777, 18 August 2009 - 05:00 PM.
#33 VIX
VIX
  • 9,497 posts
Posted 18 August 2009 - 05:09 PM
Look good. So they bolt into the clam and the diffuser bolts into the spacers. Cunning ...
I only mention the heat as I popped out earlier for about 30 mins and when I got back I went to check the diffuser was tight and it was quite hot.
Quick release fasteners for the undertrays also look cunning!
http://www.vx220.org...ers-t78942.html
chinky chinky
Edited by VIX, 18 August 2009 - 05:10 PM.
#34 NickB787
NickB787
  • 7,813 posts
Posted 18 August 2009 - 05:16 PM
chinky chinky
I did think about these also wing nuts, maybe if I can get some covered wing nut, don't know if they do them.
One thing about this method of locking is if I want more airflow I just go and get a bigger spacer and don't pay £££. I also think I probably don't need the 2 rear ones only the 5 which lock to the clam directly this would make certain the 4 air holes in the rear of the clam are free from any obstruction, as I have one covered on each side at the moment.
I have used it already and not noticed any heat issues I will check it out next time I go for a run
#35 VIX
VIX
  • 9,497 posts
Posted 18 August 2009 - 05:39 PM
My winter tidying up list is getting longer! :rolleyes: :lol:
#36 Jameshs
Jameshs
  • 3,511 posts
Posted 19 August 2009 - 09:50 AM
Looks amazing, how did you secure the arch spats??
#37 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 19 August 2009 - 09:58 AM
look like they are bended and fixed the original way am i right nick
hey we go james
#38 siztenboots
Posted 19 August 2009 - 10:01 AM
similar aim to nick , have something that was a 5 minute job to adjust on track without tools
cut up some threaded rod same as MMG screws supplied, to 100mm sections, plus some lock nuts two per stud, washers and wing nuts. Makes getting diffuser on really easy as the studs are already in position and you can do it one handed.
I have replaced the subframe bolts with longer and remove the captive nut , and converted it to a stud fixing, again with lock nuts for adjustment
lowered to 60mm
#39 NickB787
NickB787
  • 7,813 posts
Posted 20 April 2010 - 11:01 AM
update on my solution to spacing the diffuser don't bother with the ones I used they all failed the metal and rubber sections come apart, have to look at some other way, maybe Sizetenboots method
#40 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 20 April 2010 - 11:04 AM
:(...... are you off work nick :mellow:
in france they are flying in special route at the moment
a real nightmare
