If I was you mate I'd be down there tonight with a few boys & make an example of them,crack a few jaws & break a few noses & it wont happen again.....I guarantee it!Something i found which might help
"If you’ve ever been victimized by neighborhood pranksters or vandalism, you’ve likely had your car egged. While discovering an egged car is nerve racking, trying to remove the egg and yolk creates further irritation. The key is to remove the egg stain shortly after the
incident. However, if the egging occurred overnight, or while you were out of town, the yolk will crust, making removal twice and hard. Here are a few tips for removing egg from cars, without ruining the paint.
Step 1: If possible, do not allow the egg to sit on the car for an extended period, especially in the sun. Every second counts. As soon as you discover the mess, begin steps to clean the vehicle.
Step 2: Using your hand, remove all traces of the egg shell from the car.
Step 3: Once pieces of the egg shell are removed, clean the egg and yolk from the car using a soft towel. It is important to remove all traces of the egg shell. This way, you avoid scratching the surface of the car.
Step 4: Create a mixture using 1 part water and 1 part vinegar.
Step 5: Soak a towel in the mixture, and place it on the egg stain. You may also spray the mixture onto the car using a spray bottle. Allow the towel to sit for at least 15 minutes.
Step 6: Remove the towel. Dry the area using a different towel.
Step 7: If necessary, repeat steps 5 and 6.
Unfortunately, if the egg was not immediately removed, there may be damaged to the car’s paint. Review your insurance policy or vehicle warranty to see whether car egging is covered. If not, be prepared to pay a hefty price to have portions of the vehicle re-painted."
cheers for that mate il go back out no and have a look again to see if its all gone but there wasn't much egg shell just yolk and i just got some warm water and a sponge and wiped it off.
If they are too young then do their Dads!
Edited by dannynewport, 04 September 2009 - 10:18 AM.
