Wishbone Shopping List....
Posted 19 October 2009 - 06:11 PM
Posted 19 October 2009 - 06:20 PM
So the wishbones are coming off this winter o refresh the bushes, but what do I need...?
Tools and materials...?
Wishbone Bushes
Ball joints
what else?? Is a ball joint splitter essential..? If so, which type?? Any tips??
Any info welcome really
My ball joint splitter wouldn't fit so I had to get a fork shaped one. Get as narrower fork type as possible as mine was quite a tight fit
Are you replacing the track rod ends at the same time??
New penny washers (i got mine from Techieboy
Copper grease
Set of drifts as getting the washers back in is a PITA
Small wire bush to get rid of rust/crap
I used a 28mm socket and a 22mm socket (i think) with a bench vice to push the old bushes out
Posted 19 October 2009 - 06:26 PM
1 Elise Parts adjustable anti-roll bar (with poly bushes, not nylatron) clicky
2 Elise Parts anti-roll bar drop links (OEM style)
2 Elise Parts track rod ends clicky
8 Elise Parts wishbone ball joints clicky
1 set of Autobush poly wishbone bushes (16 bushes in total - kit No 5130KC) clicky
2 Spitfire uprated rear tie rods
4 8mm P clips (for holding the brake hoses to the wishbones)
2 10mm or 12mm P clips (for holding the handbrake cable to the rear wishbones)
16 M10 standard thread nyloc nuts (for the wishbone bolts)
8 upper wishbone lock/tab washers (or Nordloc washers) clicky
2 lower wishbone lock/tab washers (or Nordloc washers) clicky
16 48mm 1.5mm thick washers to replace the castor shims on the front upper wishbones
2 split pins for the driveshaft castle nuts
Plus I went the full hog and fitted 4 replacement hub/bearing packs.
Depending on whether you replace the ball joints, or not, you may find you need new Nyloc's for each of the balljoints, the drop links and track/tie rods.
Tools needed were various 15mm, 17mm and 19mm spanners and sockets. A fork type ball joint separator with quite wide jaws, the EP ball joint removal/insertion tool. A 24mm socket for the castle nut on the driveshafts. Threadlock for some of the bolts.
And a feck load of patience.
Posted 19 October 2009 - 06:40 PM
Posted 19 October 2009 - 06:43 PM
Here's a lis of everything I replaced at the start of the year:-
What are the tab washers for...?
Posted 19 October 2009 - 06:48 PM
Edited by BRG_Pete, 19 October 2009 - 06:56 PM.
Posted 19 October 2009 - 07:08 PM
M3KDJ posted a question on these recently Lock Washers
They are items 19 on the diagram, you bend one corner over the nut to hold it in place.
They're used to lock the nut in place, probably OTT if you're using nylocsWhat are the tab washers for...?
Posted 19 October 2009 - 07:12 PM
They're used to lock the wishbone bolt head and the nut, to stop them rotating and any danger of them undoing. Your old ones may be salvageable and you may be able to straighten them with some pliers but that's what you need if you're replacing them.
On Vocky's advice, I also got a heavy copper faced hammer to use to disengage the driveshafts from the hubs. The biggest pain in the arse I experienced was undoing the bolts on the hubs that hold it to the hub carriers/uprights. Access was quite hard and they were fairly well corroded. Likewise, getting the manky old hubs out of the uprights was a pain in the arse and needed the help of a hammer and a small pry bar.
Ooh yeah, something missing off the list. New hub carrier bolts from Bell & Colvill.
Posted 19 October 2009 - 07:17 PM
Edited by vocky, 19 October 2009 - 07:18 PM.
Posted 19 October 2009 - 07:21 PM
Posted 19 October 2009 - 07:22 PM
handbrake cable uses 16mm P clips
driveshafts require a deep reach 30mm socket
I blame my age and dodgy memory. 24mm must have been for the big ass bolt through the front hubs? Likewise, thought the P clips were smaller but will bow to your more recent experience.
Posted 19 October 2009 - 07:26 PM
Posted 19 October 2009 - 07:31 PM
driveshafts require a deep reach 30mm socket![]()
top tip;
use a 5mm drill bit and put four holes into the oem bushes - north, south, east, west sort of pattern.
do not drill into the wishbone![]()
then the bushes will easily come out with a small knock from a hammer/drift.
really wish I had thought of that idea at the first rather than the last bush
This drilling method worked for me, getting them in was harder, used a long bolt and washers to draw them in, like the socket method.
I needed a universal joint type socket set to get to the upper wishbone bolts, access is vert tight.
Posted 19 October 2009 - 07:33 PM
Posted 19 October 2009 - 07:38 PM
Posted 19 October 2009 - 07:40 PM
Alternatively a Dremel - simplesupper rear wishbone (front) bolts can be undone with a 3/8" 17mm socket and knuckle joint, access is tight to turn a spanner
Posted 19 October 2009 - 08:01 PM
Posted 19 October 2009 - 08:46 PM
Why undo the driveshafts? Are they in the way of the ball joint?
I had the carriers/uprights cleaned and powder coated as well as the wishbones (and various other bits and pieces) and the the old hubs were so crusty, I replaced them at the same time.
