Balance Shaft Removal On 2.2
#41
Posted 25 November 2009 - 07:31 PM
#42
Posted 25 November 2009 - 07:39 PM
#43
Posted 28 November 2009 - 06:45 PM
OK! I have now searched the internet about this balanceshaft removal.
My understanding is:
The ECOTEC engine is a world wide GM platform designed 1995-1999 at LOTUS to
fill all GM needs in this engine size.
The balanceshafts are probably there to give a smoother an torqueier engine for a typical standard car application.
GM has a racing and a Performance part department wich has developed and tested an array of tuning parts.
One of this is the GM racing Balance Shaft Elimation kit XGH676 (this has a chain follower and shorter chain).
You also need a kit to seal the oil channels.
The reinforcement of the tensioner is probably not necessary for a moderately tuned engine
The XGH676 kit is probably not commersially avaliable (will check this).
A good resource for ECOTEC tuning is this site: www.gmtunersource.com
In short I will try to do this kit myself by shorten the standard chain and modify one of the standard followers (and of course sealing the oil channels). I think this will work and give some horsepowers
More info later...
Edited by Steffe, 28 November 2009 - 06:48 PM.
#44
Posted 28 November 2009 - 07:06 PM
#45
Posted 28 November 2009 - 08:34 PM
Edited by vocky, 28 November 2009 - 08:36 PM.
#46
Posted 28 November 2009 - 10:24 PM
Edited by Steffe, 28 November 2009 - 10:26 PM.
#47
Posted 28 November 2009 - 11:30 PM
#48
Posted 29 November 2009 - 07:48 PM
#49
Posted 29 November 2009 - 07:56 PM
Well, I thought of the friction between the chain and followers. Friction between chain and balanceshaft wheels.
Internal friction in chain when it is changing bending radius.
Plus the extra mass of the moving system.
Think of this system running at 6000rpm, probably at least 1,2hp extra loss
Personally I don't see that at all, the idler wheels turn with so little friction, you're probably talking 0.01bhp, it's negligible.
#50
Posted 29 November 2009 - 08:35 PM
#51
Posted 29 November 2009 - 09:46 PM
Edited by Steffe, 29 November 2009 - 09:48 PM.
#52
Posted 29 November 2009 - 10:04 PM
Vocky it feels that you really has thought this through
You have convinced me its probably better to put tuning-energi in other areas.
Though I still think that there is some measurable losses when you force the chain around those
extra bendings, but we can leave it at that.
Thank you for your input (Vocky and Muncher).
As you say yes there will be some but the time and effort you put into that would be far better spent in other areas.
#53
Posted 29 November 2009 - 10:12 PM
I really, really wanted to do the short chain method, but the balancer delete is a proven mod and you don't gain anything more from spending money doing the short chain version.
balancer delete is a free mod, the short chain method requires at least a pair of front oilway blanking plugs and another chain guide making - the standard guides don't fit, I've already tried
but I'm tempted to fit an electric pump and remove the chain completely
How is it free I thought you need to buy plain shafts or modified gears with no shaft?
#54
Posted 29 November 2009 - 10:17 PM
Almost free. You need to cut your shafts, or have someone do it for you.How is it free I thought you need to buy plain shafts or modified gears with no shaft?
#55
As I understand it:
-take shafts+sprockets out and dismantle,
-cut counter weights off shaft ends,
-knock bearings further into block to cover the oil feed,
-refit whats left of the shafts to the sprockets and refit.
Edited by rsg, 29 November 2009 - 10:18 PM.
#56
Posted 29 November 2009 - 10:33 PM
A fellow Dutch Speedster mechanic made his own version of the short chain method with new chainguides. (I have one...)
See: http://www.speedster...p...c&start=150
He also made inserts for the old shaft bearings, but the major problem still is the necessary shorter chain. In September there was still no solution for this yet...
#57
Posted 30 November 2009 - 10:51 AM
Edited by vocky, 30 November 2009 - 10:54 AM.
#58
Posted 30 November 2009 - 10:32 PM
