Big Power Vxt Project
4728 replies to this topic
#1821 Nev
Posted 25 June 2013 - 09:15 PM
Hi Tim, I'm seriously considering a new 3rd party ECU. Bloody expensive (for me anyway), but everyone I know with proper car experience (and some have driven the car) is telling me to switch away from OEM ECU.
Steves insights look like great progress though, hopefully he will be the new community mapper :)
#1822 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 25 June 2013 - 09:22 PM
Are you likely to be moving quickly on it or just enjoying the car for the summer first? You confident in the safety of your current map I suppose is the key question.
#1823 fezzasus
Posted 26 June 2013 - 07:22 AM
Depends if he is going to match Z22SE pricing and charge 875 euros
#1824 Nev
Posted 26 June 2013 - 08:43 AM
Fairly quickly as I cant afford another case of shiny glazed bores.
#1825 cnrandall
cnrandall
  • 943 posts
Posted 26 June 2013 - 11:04 AM
Just go and buy yourself a Syvecs and be done with it!
#1826 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2013 - 07:30 PM
Hi Tim, I'm seriously considering a new 3rd party ECU. Bloody expensive (for me anyway), but everyone I know with proper car experience (and some have driven the car) is telling me to switch away from OEM ECU.   Steves insights look like great progress though, hopefully he will be the new community mapper :)
Nev, you know it makes sense!
#1827 steveboyslim
steveboyslim
  • 120 posts
Posted 26 June 2013 - 07:59 PM
I have been telling him that since you first mentioned it.
I expect to use the Life (Syvecs) F88 RX or RS on mine.
Steve
#1828 Nev
Posted 27 June 2013 - 01:55 PM
Bit the bullet and insured the thing today.
Went with Henderon Taylor (underwritten by Aviva), based on a recommendation from Simon (MrSimba) on here. Good service, very mod friendly, no excessive questioning about my dogs name and whether I want life insurance etc etc . Oh and cheapest price too, including track day cover and international driving at no extra cost.
Edited by Nev, 27 June 2013 - 02:01 PM.
#1829 CocoPops
CocoPops
  • 17,182 posts
Posted 27 June 2013 - 02:03 PM
Better get it on track now then to use it properly thumbsup
#1830 siztenboots
Posted 27 June 2013 - 02:14 PM
would it be cruel to ask the annual mileage
#1831 Nev
Posted 27 June 2013 - 02:17 PM
LOL, you have PM.
Edited by Nev, 27 June 2013 - 02:21 PM.
#1832 Nev
Posted 28 June 2013 - 03:58 PM
Had a bit of an embarrassing moment today, when I was crawling out of the MOT station in 1st gear a nearby car alarm went off whilst all the mechanics were watching. Then just as I was losing my blush 200 metres further up the road Nipper set another off, pretty damn close to the local police station. :blush:
Edited by Nev, 28 June 2013 - 04:01 PM.
#1833 VXT Tim
VXT Tim
  • 11,421 posts
Posted 28 June 2013 - 04:33 PM
Chav
#1834 smiley
Posted 28 June 2013 - 05:52 PM
:poke:
#1835 Nev
Posted 02 July 2013 - 08:37 AM
120 miles of running in so far and everything is looking and feeling good, even the brakes feel good once warmed up and stomped on hard after being parked up for virtually all the winter. I managed to blow a boost pipe off last night as I took it to 5000 RPM and close to full boost - easily remedied.
Edited by Nev, 02 July 2013 - 08:38 AM.
#1836 siztenboots
Posted 02 July 2013 - 08:49 AM
What is the main issue you have, I know you had a local guy get some data logs on yours.
To progress the .org remap project, it would help to gather as many examples of what people have and their feedback of improvements. The main areas I can help are to get your custom MAF , plus you can put back in your bigger injectors and run the fuel rail at a more normal 3 bar, and have a very fine adjustment in the map.
#1837 Nev
Posted 02 July 2013 - 09:07 AM
Main thing in order of importance:
1: Overfueling in places (so my bores don't get washed and oil doesn't contaminate).
2: Underfueling in places.
3: MAF calibration is poor, suspect it may be causing the poor idle, in combination with simply being too big to get a low reading.
4: Improve smoothness of delivery during spool up.
5: Want to reduce power by about 50 BHP (ie reduce boost demand).
6. Check that max boost is set to 1.4 Bar (as it was told it was), as it has shown spikes to 2.0 bar on the dyno. Then lower it to something like 1.2 Bar.
Other things which are not possible on OEM management that would be nice:
1. Traction control.
2. Eliminate MAF.
3. Multiple maps.
4. Switch to run the wastegate at base spring pressure (8 PSI in my case). Ie Switch off EBC and run the wastegate directly from inlet manifold pressure.
Edited by Nev, 02 July 2013 - 09:17 AM.
#1838 Nev
Posted 03 July 2013 - 04:57 PM
Blew a boost pipe off yesterday for a second time when I semi-wellied it to 5000 RPM, so I've tried another way of clamping the hose down over the mouth of the non standard throttle body. Tricky to do and I might need to get a bespoke sleeve machined up to mate to the TB mouth properly instead of my current bodge. Anyway I did a pressure test of the entire boost system with my air compressor to 1.7 Bar and found quite a large leak from a poorly seated clip and have fixed that now.
Went for a quick drive before the rush hour this afternoon after work and in the few gaps between cars gave it some squirts, god it's fast without the boost leak, I still wonder how I ever drove it at full revs. Am waiting for the traffic to dissipate and try again later to get some more running in miles on the engine.
Edited by Nev, 03 July 2013 - 05:07 PM.
#1839 Nev
Posted 06 July 2013 - 08:17 AM
Just been out for an early morning country lane bash. 58 glorious miles with the sun shining, minimal traffic, lush green trees, wind in my hair, ears bleeding from the noise. Looooverly. rallly
Have done 200 miles now, so the engine is more or less run in I think. Took it up to 6000 revs before I chickened out and the boost pipe stayed on :)
#1840 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 07 July 2013 - 07:12 AM
I am envious of you Nev, glad your up, running and happy
