Supercharged Cars Top End...?
Posted 13 December 2009 - 05:30 PM
Posted 13 December 2009 - 05:39 PM
Posted 13 December 2009 - 05:46 PM
Posted 13 December 2009 - 05:54 PM
OEM ecu is limited, "standalone" will let you know
rev limited or MPH limited? I'd no idea they had an MPH limit if they do, everything has an RPM limit. The gearing isn't particularly high in the VX220 what does 5th give at 3000rpm? Is it about 70mph if so 6500rpm is a bit over 140mph.
Edited by Steve B, 13 December 2009 - 05:57 PM.
Posted 13 December 2009 - 06:05 PM
Posted 13 December 2009 - 06:09 PM
Posted 13 December 2009 - 06:46 PM
Turned out there is a seperate speed limiter on the ECU which kicks in at 242km/h
Haven't driven an unlimited version yet, but at least I now know I can get 242km/h with the current state of trim
Around 151 mph according to Mark
Posted 13 December 2009 - 07:05 PM
Posted 13 December 2009 - 07:16 PM
Posted 13 December 2009 - 07:31 PM
private testing day got me to speedo indicated 150 sc's with a little more to go
thats good going
Posted 13 December 2009 - 07:41 PM
Posted 13 December 2009 - 08:19 PM
Fcuk that, springs to mind.with a 6850 rev limit 160mph is the max speed for a 2.2 vx / sc
Posted 13 December 2009 - 08:21 PM
Posted 13 December 2009 - 08:23 PM
Wuss.6850 is quite high is it not? For a rev limit?
Posted 13 December 2009 - 08:36 PM
Posted 13 December 2009 - 08:40 PM
Posted 13 December 2009 - 08:45 PM
That's not impossible to handle of course. Might be good to consider undersized main bearings if you go much higher than that. Oil shear in the bearings can be an issue. By reducing the diameter you reduce the surface speed.8200 with out throwing a rod I'll have some of that
Posted 13 December 2009 - 09:06 PM
Posted 13 December 2009 - 09:17 PM
Posted 14 December 2009 - 07:58 AM
