The headlights were the real and very obvious problem so I raised the front back up again. The light pattern was hitting the road about 10 feet ahead but turn in was sharp.
I went for 205/45/16 and get no rubbing on TMS spec TDs.
speed sensor is in the nearside rear hub , so not change to mileage or speedo
unfortunately any tyres sizes eg. 195/40/17 are just a rough guide and won't be in any way exact or comparable. For instance the Kumho KU31 205/50/16 which several people have fitted to a 16" rim has an actual width of 214mm so very wide.
They do look too small though, lowering the front to look good gives a rake of about 20mm and a very low front number plate
downsides there are ,
fuel tank reading slightly affected
headlights / driving lights aim lowered
Martin, do you have the settings used for your geo? I would be surprised if you had a bad setup considering who did it but wondering what setup you had.
