60-2 Thigger Wheel
83 replies to this topic
#1 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 08 March 2010 - 12:45 PM
Just thought I would help out :D
#2 The Batman
Posted 08 March 2010 - 12:46 PM
sort ya spelling out chav :lol:
#3 NickB787
NickB787
  • 7,813 posts
Posted 08 March 2010 - 12:48 PM
:lol: :lol: That's how I get peoples attention,
MODS :D
#4 alanoo
alanoo
  • 1,324 posts
Posted 08 March 2010 - 12:50 PM
Why specifically a 60-2 Nick ?
#5 NickB787
NickB787
  • 7,813 posts
Posted 08 March 2010 - 12:53 PM
I am keeping my options open, DTA.and loads of other ecu's use 60-2 (also the z20let) :D
#6 alanoo
alanoo
  • 1,324 posts
Posted 08 March 2010 - 12:54 PM
Yep but are not limited to 60-2 right ?
#7 Welshiejon
Welshiejon
  • 177 posts
  • Interests:building race engines and working on fast cars
Posted 08 March 2010 - 01:06 PM
Im using dta p8pro with the 36-1 [attachment=21828:vx220.jpg] as we mentioned
Edited by Welshiejon, 08 March 2010 - 01:06 PM.
#8 NickB787
NickB787
  • 7,813 posts
Posted 08 March 2010 - 01:07 PM
true, most standalone ecu's have multiple trigger wheel patterns built in I want the 60-2 just in case.
can you make a 60-2 then? there are some around but with you having worked with the pulley and have it with you I know it would fit straight off.
Edited by NickB777, 08 March 2010 - 01:09 PM.
#9 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 08 March 2010 - 01:10 PM
Has anyone on here tried the Haltech Sprint 500 yet?
#10 rabidh
rabidh
  • 1,640 posts
Posted 08 March 2010 - 01:16 PM
I guess it's a bit OTT - but isn't there a crank that already has one? Definitely the 2.4L crank has one, but the stroke is different... What about the Z22YH?
#11 Welshiejon
Welshiejon
  • 177 posts
ill draw it up wont be a problem
Edited by Welshiejon, 08 March 2010 - 01:35 PM.
#12 NickB787
NickB787
  • 7,813 posts
Posted 08 March 2010 - 01:26 PM
Thanks I believe centre bore will be 50mm for the bolt and I think its 48mm from the centre point for the fixing bolts, can the fixing bolt holes be arced to allow for some fine adjustment?
I don't want to change crank (even if I could there is no need) as the z22se has the 7-1 pattern so any after market ecu will require a new wheel pattern and since the z20let ecu needs a 60-2 i decided to cover all bases
#13 Welshiejon
Welshiejon
  • 177 posts
Posted 08 March 2010 - 01:37 PM
[attachment=21830:36-1.PDF] this is what i plan to run makes for easy set up 10 deg per gap also if you going to rev it high then you need the larger gaps to give the sensor a chance im expecting to test my engine to about 8000rpm
Edited by Welshiejon, 08 March 2010 - 02:30 PM.
#14 Welshiejon
Welshiejon
  • 177 posts
Posted 08 March 2010 - 02:59 PM
[attachment=21831:60-2.PDF] bit bigger dia
#15 NickB787
NickB787
  • 7,813 posts
Posted 08 March 2010 - 03:09 PM
looks really good chinky chinky I wonder about the missing teeth position in relation to DTC? is it worth not removing any teeth(creating the gap) untill that is known? can it be done by hand later?
#16 Welshiejon
Welshiejon
  • 177 posts
Posted 08 March 2010 - 05:00 PM
Well when i do engines on the brake you always have to set the compensation figer first you will never get ti to sit just writh when you just check with timming light and enter figer and away you go the ecu knows exactly where tdc is
#17 Welshiejon
Welshiejon
  • 177 posts
Posted 09 March 2010 - 09:13 AM
only 2 guys needing these?
#18 rik
rik
  • 2,187 posts
Posted 09 March 2010 - 09:21 AM
if u can get it running enough to use a timing light then that will give u the exact btdc figure You'll have to make a mounting bracket too for mag sensor
#19 Welshiejon
Welshiejon
  • 177 posts
Posted 09 March 2010 - 09:38 AM
Ill be making the sensor bracket soon
#20 NickB787
NickB787
  • 7,813 posts
Posted 09 March 2010 - 09:39 AM
:D aaaaaahhhhhh :D
