Cam Sensor Info
Posted 10 March 2010 - 09:06 AM
Posted 10 March 2010 - 09:16 AM
Posted 10 March 2010 - 09:22 AM
the 20XE did... it then got updated to the "ecotec" XEV and gained a cam sensor which followed to the LET's too.
most pre 1995 stuff ran without.
I am interested to see what ecu's have run without it and if they are cracked
Posted 10 March 2010 - 09:45 AM
Posted 10 March 2010 - 10:57 AM
Edited by rabidh, 10 March 2010 - 11:27 AM.
Posted 10 March 2010 - 11:03 AM
Posted 10 March 2010 - 12:04 PM
z20let doesn't seem to use the cam sensor , more as a reality check than essential
the camshaft sensor is needed when using standard mangement, otherwise your ecu will go into 'safe mode' restricting the revs.
Posted 10 March 2010 - 12:58 PM
Posted 10 March 2010 - 01:00 PM
from my testing it made no difference to performance or ignition timing / fuel trims
Posted 10 March 2010 - 01:01 PM
Posted 10 March 2010 - 01:05 PM
sizeten are you saying you are running without one then?
to eliminate the sensor and wiring loom it was one of the things we tried for extended mileage, I could not get it to raise a MIL code, it probably just substitutes a default value.
pretty sure it is 100% crankshaft timed and fuelled.
Posted 10 March 2010 - 01:13 PM
That would be handy.pretty sure it is 100% crankshaft timed and fuelled.
Posted 10 March 2010 - 01:21 PM
Posted 10 March 2010 - 01:24 PM
thinking about it , the crank trigger wheel turns every rev , whereas the camshalf wheel has less teeth and only turns once every 2 crank revolutions, so probably would not tell you much.
it only tells you that X cylinder is at TDC and to therefore base all fuel calculations and which injector/plug to fire when if using sequential and individual plug fring.
Posted 10 March 2010 - 01:30 PM
sorry , as you say , the odd or even cylinder firing, its wasted spark , so just fuel ?
its got a 50% chance , but is there a missing trigger on the cam to tell it which
Edited by siztenboots, 10 March 2010 - 01:31 PM.
Posted 10 March 2010 - 01:35 PM
Posted 10 March 2010 - 01:40 PM
tbh the lobe can be anywhere as the ecu software can be set to accept any marker/crank poistion setup (assuming you can get at the code lol)
This is what I reckon - but I guess the question is whether the Motronic earlier mentioned will (or can be made to) cope with that. It has both crank and cam sensors, so it's a good start.
edit: I guess we're a bit off-topic now
Edited by rabidh, 10 March 2010 - 01:41 PM.
Posted 10 March 2010 - 01:49 PM
z20let timing wheel ( note the balancer shaft drive gear )
Posted 10 March 2010 - 01:56 PM
