Mini Onboard Cameras
146 replies to this topic
#101 rsg
rsg
  • 3,306 posts
Posted 29 March 2010 - 03:35 PM
Good vid from the driftworks boys
#102 Duncan_F
Duncan_F
  • 3,725 posts
Posted 29 March 2010 - 05:16 PM
:lol: Love the "this is taped to my head" bit.
#103 siztenboots
Posted 30 March 2010 - 06:46 PM
has anyone translated the instructions yet? can't seem to figure out the status of the yellow light
#104 smiley
Posted 30 March 2010 - 07:24 PM
The translation is supposted to be in english, unless you got yhe cheaper version with just chinese manual :P
http://chucklohr.com...a-4-manual.html
In a nutshell, to start you get about 3 little blinks. it's then running, so NO visual confirmation whatsoever during running.
(hence the concept of spycam)
#105 Kieran B
Kieran B
  • 1,101 posts
Posted 05 April 2010 - 03:54 PM
Has any one figured out how to set the correct date and time? read the instructions but doesnt seem to work.. :tumble:
#106 smiley
Posted 05 April 2010 - 07:37 PM
Sample file: http://www.auto-edit...ve/foto/TAG.zip Extract it, and copy thix text file to the root of your camera memory card. ( so not in a subdirectory or anything) As soon as you start the camera, the built in logic will pick up this file, extract the date/time and will insert it in every movie you will make with it, as from then. (same timestamp for all movies) The logic will automatically delete the TAG file, once loaded in memory, so it looks dissapeared from memory card. To change the date/time copy the TAG.txt with the new date you put in via notepad to the root of your camera memory again. So every date/time change is a new excersize Hope this makes sence.
Edited by smiley, 05 April 2010 - 07:37 PM.
#107 Kieran B
Kieran B
  • 1,101 posts
Posted 05 April 2010 - 09:42 PM
Sample file:
thanks
#108 Retset
Retset
  • 1,766 posts
Posted 08 April 2010 - 10:02 AM
Didn't get much chance to attach to a car yet but we took them on a family walk and I shot random steam train clips and uploaded one. Just trimmed and titled using Windows Live Movie Maker and uploaded to YouTube using it's built in feature. You can certainly see that frames get duplicated which leads to the occasional stutter. However, I have about 30 minutes of video in all and the quality is way better than it should be for £15 (half camera, half 4GB card).
My steam train video.
#109 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 11 April 2010 - 08:00 AM
Used my spy camera at Goodwood the other day and had great results. I bought 2 cameras and propose to use in a run and standby type of arrangement. I would like to be able to charge one of the cameras from the cars lighter socket. does anyone know of a suitable bit of kit to do this? Cheers in advance.
Edited by Sutol, 11 April 2010 - 08:00 AM.
#110 siztenboots
Posted 11 April 2010 - 08:21 AM
twin usb cigarette should step down the voltage to 5v supply, then you can use a standard usb A to micro B cable
#111 Retset
Retset
  • 1,766 posts
Posted 12 April 2010 - 07:56 AM
I have assumed that the same sort of lead you run a TomTom with (12V car socket to mini USB) must be fine and they are cheap as chips on fleabay.
#112 System-G
System-G
  • 333 posts
  • Interests:Trackdays, Racing, Snowboarding, MTB, Computing, Scuba, Gigs etc...
Posted 13 April 2010 - 06:08 PM
I saw this thread yesterday and loked up these little cameras and for the money I'm quite impressed thumbsup I followed the original ebay link in this thread and checked out the sellers feedback and wasn't confident so searched and found another seller (there are quite few!) I eventually bought two from this listing: http://cgi.ebay.co.u...=item3a59ca855c
#113 TheStotts
TheStotts
  • 1,130 posts
Posted 13 April 2010 - 06:52 PM
Ordered a couple of these from here last week. Will post up feedback when (if?) they arrive thumbsup
#114 Sutol
Sutol
  • 8,122 posts
Posted 13 April 2010 - 06:57 PM
fair range of prices there :lol:
#115 Ebo100
Ebo100
  • 654 posts
Posted 16 April 2010 - 07:45 PM
Just had my first play with my camera tonight and I'm not really that impressed. I loaded a 4GB SD card and had a drive around with the camera blue tacked to the top of the windscreen surround and later blue tacked to the dash board.I found the video is very jerky with frames getting dropped with whole sections looking more like a slide show of still photos. Anyone had videos like this? At first I thought is was just bumpy roads but even on the rare sections of super smooth it only manages a few frames before is misses. Could it be the memory card not being able to process the data quick enough?
#116 Sutol
Sutol
  • 8,122 posts
Posted 16 April 2010 - 08:02 PM
I've had very good results. It could be your card. There is a free download to test SD cards
take a look thru this, I found it useful clicky I found the software on that site it's called h2testw.exe
hth
#117 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 16 April 2010 - 10:11 PM
Could be the card because mine was fairly uninterrupted. But tbh with a £7 camera of course you'll get some.
#118 System-G
System-G
  • 333 posts
Posted 17 April 2010 - 07:28 AM
Standard SD cards will be rubbish. You need SDHC or Class 4 minimum for video/photos thumbsup
I am an E-Commerce Exec for an online company who sells decent compatible cards. The link below is similar to the sort of quality you need to look for.
Micro SDHC
Edited by System-G, 17 April 2010 - 07:28 AM.
#119 Ebo100
Ebo100
  • 654 posts
Posted 17 April 2010 - 08:22 AM
hth
Thanks Sutol, I ran the test program and it seems my card is OK. Here are my results:-
Warning: Only 3773 of 3774 MByte tested.
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 4.68 MByte/s
Reading speed: 8.43 MByte/s
H2testw v1.4
Micro SDHC
I have the very same card as your link, Kingston SDHC 4GB, I'm always wary about buying cheap cards so tend to stick with a make I am familiar with.
I will continue to play with it, but might just send for a second one from the link you posted. thumbsup
#120 dw1
dw1
  • 3,043 posts
Posted 17 April 2010 - 08:56 AM
hth
H2testw v1.4
Micro SDHC
Got mine from these boys,
http://www.memorybit...oducts_id=17868 Its Trascend which are a decent make SDHC and class 6. Don't know how it compares to Kingston but it has lifetime warranty and is a class 6 so for that price can't grumble.
Put Spring12 in the discount code box for 12% off and you also get free delivery. I got mine in two days. Impressive service.
