Airbag Squib
28 replies to this topic
#1 yaaan
yaaan
  • 956 posts
Posted 01 April 2010 - 01:57 PM
Had the airbag warning light on for a while now and finally got around to ordering an OP-COM which has arrived today. Plugged it in and got the following: 00031 - Driver Airbag Squib Circuit High Resistance Present. From other threads on here it seems that replacing the squib is the solution of choice but I'm unable to find if this is a specific VX squib or do ones from other vauxhall models fit? I'd rather not had over £50 for a new one to vauxhall if I can avoid it so ebay maybe the solution but none there identified as VX ones :unsure:
Edited by yaaan, 01 April 2010 - 01:58 PM.
#2 techieboy
Posted 01 April 2010 - 02:04 PM
There's one for sale in the Parts for Sale section.
#3 yaaan
yaaan
  • 956 posts
Posted 01 April 2010 - 02:39 PM
Cool, cheers chinky chinky
#4 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 01 April 2010 - 03:45 PM
Same as Lotus, Lamborghini and a few others use iirc. Due to the size it fits in small (momo) steering wheels nicely. That might be the whole airbag module though, the squib might be far more generic. Please correct me if I'm wrong though :unsure:
Edited by Ouchie, 01 April 2010 - 03:46 PM.
#5 slindborg
Posted 01 April 2010 - 04:04 PM
dont quote me, but I do believe its from a Corsa (which came from the Omega :lol: and wasnt re-calibrated either :s :lol:)
#6 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 01 April 2010 - 04:44 PM
I bought a Corsa B one from fleabay for 99p. A bargain I thought, although it was the same size and nigh on identical looking, it won't clear the fault. It also had a different part number which may or may not be of any significance. I've replied to your PM yaaan :)
#7 Scotsdave
Scotsdave
  • 761 posts
  • Interests:Muff diving
Posted 09 November 2010 - 07:59 PM
Sorry to bump this. Did you get this sorted packs? Did it need a new bag or was the corsa squib faulty? Cheers
#8 Anarchy
Anarchy
  • 2,237 posts
Posted 09 November 2010 - 08:15 PM
I suspected my 'squib' so I pulled it apart and I seriously cant see much to go wrong with it, its just a roll of wire like a tape measure and there was no resistance when I checked it so I think it is OK. On another note surely the squib is the explosive/firework part that fire the air bag off, definately nothing like that in there.
#9 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 09 November 2010 - 08:34 PM
If you have OPCOM you should have a function where you can switch the car over to a non-airbag type setup. Ie Pre-Tensioners ONLY. Shouldn't care about the squib at all then thumbsup.
#10 Scotsdave
Scotsdave
  • 761 posts
Posted 09 November 2010 - 08:35 PM
Well the part known as the "squib" is actually just a coil of wire that lets you turn the wheel while keeping the connection to the bag. This part isn't actually a squib like you correctly say the squib is built in to the bag.
#11 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 09 November 2010 - 08:44 PM
Nah mate the squib is under the dash isn't it?? I thought squib was the airbag ecu...?
#12 Ben NA
Ben NA
  • 480 posts
Posted 09 November 2010 - 09:07 PM
I took my airbag out a while back and turned the ignition on as I was testing the wiring to find a different fault. Obviously didn't realise this would permanently activate the airbag light! Will I have to go to Vauxhall to get this cancelled? I have one of those bluetooth OBDII readers but it says no fault codes detected and the clear fault code function won't clear it :(
#13 Scotsdave
Scotsdave
  • 761 posts
Posted 09 November 2010 - 09:34 PM
You need an opcom to reset airbag lights. Or take it to vauxhall eek.
JJJ- a Squib is an explosive so mounted in the airbag. The bit under the dash is just the control unit.
#14 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 09 November 2010 - 09:53 PM
Good luck doing that!
I wouldn't just assume that they'd know what to do! :rolleyes:
#15 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 09 November 2010 - 10:02 PM
An OP-COM may not be sufficient enough to clear the airbag fault. I had to get my airbag ECU flashed.
#16 Ben NA
Ben NA
  • 480 posts
Posted 09 November 2010 - 10:14 PM
Wow that sucks. I guess it's designed that way for safety but flashing the airbag ecu...really! I'll just put a sticker over the light. Fingers crossed the airbag will still work.
#17 techieboy
Posted 09 November 2010 - 10:15 PM
Indeed it is. :thumbsup:
Back in the very dim and distant past I worked for a film and theatre lighting and special effects company in London and we used to use lots of them for gunfire (or at least the bullet impact) effects.
#18 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 09 November 2010 - 10:17 PM
#19 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
this is character :closedeyes:
#20 d4nnyk
d4nnyk
  • 769 posts
Posted 10 November 2010 - 08:09 AM
When the airbag light is on, the whole airbag system is de-activated so definately won't work,plus an MOT failure (unless they don't notice the sticker). I had the same issue as packs, just get the airbag ecu flashed was about £35 by a bloke from ebay
