Brake Bleeding Issues
Posted 22 April 2010 - 03:38 PM
Posted 22 April 2010 - 03:47 PM
Posted 22 April 2010 - 04:03 PM
Right, you'll need to turn the front calipers upside down, bleed them then bleed again the right way up after. If they still feel spongy after this then you need to find some gravel and lock the front wheels up to activate the abs a couple of time. Obviously be very careful. Then bleed again all round turning the fronts upside down again. You may need to do it a few times. You may as well bleed the clutch while your doing the rest but it wont effect the brakes
Looks like i wont be getting it done tonight! Couple of questions:
Can I be certain the clutch does not have air in it, ie is there a non-return valve on its system?
How can I be sure the master cylinder is in good shape?
Cheers
Posted 22 April 2010 - 04:10 PM
Posted 22 April 2010 - 04:23 PM
there wont be a valve but as the resevior is at the top the air wont go down into the clutch pipes on there own. You can check just by seeing if the clutch works.
Its possible about the master cylinder but id eiminate the chance of it being air. the brakes are notoriously crap to bleed so its best to not let air get in at all when changing fluid. Obviously in your case it cannot be avoided
Yea, crap to bleed is an understatement if the procedure you outlined is what is usually done. At least I have tomorrow to do it. Bloody frustrating as the lines went on pretty well. Fiddly to do, but no major dramas. Rears were a positive pleasure!
Down the motor factors for some more brake fluid tomorrow morning and then get rotating!
Cheers ZB.
Posted 22 April 2010 - 04:29 PM
need to do mine i guest joe and vocky will be there to advise me
what are the procedure
Posted 22 April 2010 - 05:35 PM
Posted 22 August 2019 - 02:25 PM
Bit of a bump..
I fear I'm going to be having to rotate my calipers to remove air..
What actually is the practical method for doing this?
I presume I can only do this with a presure bleeder, rather than pumping the brake pedal?
With ezi-bleed take caliper off, rotate, hold upside down and wait for air to pass? - Just to be clear, with the ez-bleed or similar, with the caliper off the car the piston won't clamp into the pad?
Posted 22 August 2019 - 04:21 PM
Edited by Talk-torque, 22 August 2019 - 04:24 PM.
Posted 22 August 2019 - 04:43 PM
No need for anything extra.
Posted 22 August 2019 - 06:17 PM
Posted 22 August 2019 - 06:30 PM
https://wiki.seloc.o...leed_the_brakes
Is the bleeding order correct? My understanding is longest brake line to shortest is the correct order. It says OSR, NSR, OSF, NSF. I would have thought NSR OSR NSF OSF, but then I could be mistaken?
