2.2 Balance Shaft Removeal Good Idea Or Bad
30 replies to this topic
#1 jkm06
jkm06
  • 74 posts
  • Interests:spray painting car and repairing them both bodywork and mec. Goin to the gym and enjoy a good film
Posted 22 April 2010 - 09:21 PM
Hi all
bein looking at ways to get better performance from 2.2 and one of the ways is the balance shaft removeal just wondering if their are ne problems by do this to the engine.?.Posted Image
#2 SteveA
SteveA
  • 9,158 posts
Posted 23 April 2010 - 07:57 AM
AFAIK balance shafts are there to counteract engine vibration, removing them will make the car shake a lot more. Not sure you will see any performance improvement (other than the weight loss)
#3 spuk87
spuk87
    Ex-owner
  • 3,624 posts
Posted 23 April 2010 - 07:59 AM
Posted Image . I think the engine will rev more freely as well, not sure of the potential for damage.
#4 Phear
Phear
  • 1,125 posts
Posted 23 April 2010 - 08:00 AM
You will get slightly more engine vibrations, certainly not much more. You might gain a bhp or 2 but not much but the engine will rev a lot easier. Well worth doing but only if you have the engine out for some other reason already.
#5 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 23 April 2010 - 09:40 AM
its not possible to do it with the engine in the car you will get some extra virbation but not much.
#6 Muncher
Muncher
  • 4,494 posts
Posted 23 April 2010 - 12:53 PM
I didn't notice any extra vibration at all. Supposed to release 10bhp according to the GM build book.
#7 Nev
Posted 23 April 2010 - 02:19 PM
Muncher, can you give me the link to that GM build book pls, sounds like interesting midnight reading !
#8 techieboy
Posted 23 April 2010 - 02:24 PM
Nev, I think the drugs might be having a bigger effect on you than you realise. You yourself posted a link to the GM Ecotec build book a couple of days ago, in the Honda engine into a VX thread. :lol:
#9 2-20
2-20
  • 1,317 posts
Posted 23 April 2010 - 03:22 PM
On page 2
Here
Edited by 2-20, 23 April 2010 - 03:35 PM.
#10 Nev
Posted 23 April 2010 - 04:05 PM
Nev, I think the drugs might be having a bigger effect on you than you realise. You yourself posted a link to the GM Ecotec build book a couple of days ago, in the Honda engine into a VX thread. Posted Image
UH OHHH, SPAGHETTI OHH !!
I am trying to ween myself of them Posted Image
Edited by Nev, 23 April 2010 - 04:06 PM.
#11 2-20
2-20
  • 1,317 posts
Posted 23 April 2010 - 04:11 PM
The other parts of the article are here:
HERE
#12 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 23 April 2010 - 04:12 PM
This to me is like "Vx towball. Good or bad?" Or "22" rims on a vx220...good idea?" I'd definitely want rid of the shafts.
#13 jkm06
jkm06
  • 74 posts
Posted 23 April 2010 - 05:51 PM
thank for the info lads. I'm currently in the middle of doin sum changes on the front clam and going to b remove rear clam to repaint it with the rest of the vx. so was think y clam is off do some engine mods.
#14 Phear
Phear
  • 1,125 posts
Posted 23 April 2010 - 07:48 PM
Clam off won't cut it, engine has to come out completely to remove the balance shafts.
#15 vocky
Posted 23 April 2010 - 07:55 PM
there are many z22se engines running with the balancer delete fitted thumbsup
#16 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 23 April 2010 - 08:10 PM
included mine next week
are they worth anything:mellow:.......:lol: i'll give them to joe :D
#17 redvts
redvts
  • 1,472 posts
Posted 23 April 2010 - 08:32 PM
u good with paint work on plastic? I'm gonna need some bubbling sorted in the future, r the repairs to ur rear clam for bubbling?
#18 Paulus H
Paulus H
  • 2,063 posts
Posted 23 April 2010 - 09:25 PM
If I remember how David Visard put it... Assume the car weighs 1,000 kg and the weight of the moving engine (reciprocating and rotating) parts are 100kg. If the reduction ratio in first gear is 10:1 then the car has to move, 1,000kg divided by 10 (gear ratio reduction) = 100kg PLUS 100kg of moving engine parts Total 200 kg Reduce the mass of the parts moving in the engine by 15kg (for instance by removing the balancer shafts) and the car now only has to move 185kg. Therefore acceleration in first gear is improved. The same is true in second gear but obviously to a lesser extent. I am sure the smart guys out there will say this is not all of the story... The above example just takes into account rotating weight NOT rotating inertia. The difference being removing 15kg from a component with a diameter of 50 m/m removes less rotating inertia than removing 15kg from the outside diameter of a component with a much larger diameter such as a flywheel.
#19 petrolhead1
petrolhead1
  • 936 posts
  • Interests:Windsurfing and Sailing
    Karting
    My family
Posted 23 April 2010 - 10:07 PM
Vocky is widely reckonised as a tuning guru when it comes to the Z22SE and I am not. Consider the origins of the engine. It was built for the Vectra (repmobile which would spend many hours/days trolling the motorway network with minimum maintenance and drivers who would be much more concerned about vibration than performance). Do the balancer shafts improve engine longevity - I don't know but probably. Does removing them improve performance almost certainly(based on all the comments here). So it has to be your decision based on the opinions and facts you can extract from the forum and any other sources.
If it were me and money was no object I think I would, on balance, go for it.
#20 jkm06
jkm06
  • 74 posts
Posted 24 April 2010 - 12:19 AM
Engine will be coming out. plan for the engine are to get the flywheel lighten and balance with sum crank work and also sum head.
redvts i' ll post some pics on the car soon. just got to pick if it stayin red or goin yellowPosted Image
Edited by jkm06, 24 April 2010 - 12:20 AM.
