Had a diagnostic on it and its code suggests there is a transponder problem, weird as car initially started ok but it seems that it had now lost signal from the transponder.
Maybe a loose wire. Anyone got any other ideas, remember car initially started and then cut out?
I had the same issue a couple of months ago, car would not start, tested the starter relay etc.. put OP-COM on and it stated immobilizer fault. All lights worked etc..
I brought a new main battery and hey presto everything was fine. I am not saying it is definately the same fault but if I had the same issues again the battery would be changed straight away!!! worth a try??
EDIT: just re-read your first post, as you had to jump start your vx in the first place, I am really thinking battery
Edited by d4nnyk, 30 April 2010 - 03:20 PM.
