Na To Turbo Conversion
Posted 27 April 2010 - 12:18 PM
Posted 27 April 2010 - 12:29 PM
Posted 27 April 2010 - 12:34 PM
So are you planning to put the Z20LEH into the NA?
imho that would be the "better" option if you want to use the current parts...
however you can sell them on MIG/vauxhsport, get an N/A and dive in with a good S/C build on the 2.2.
Posted 27 April 2010 - 12:39 PM
Posted 27 April 2010 - 12:41 PM
Posted 27 April 2010 - 12:47 PM
It has been done before, but it will be worth less than the standard NA if you come to sell it due to the level of modification.
I've said it before, and I'll say it again. if your going for the levels of power where you need to change the internals, IE 350-400 bhp then the Z22SE engine is a better starting point due to all the component available in the US.
if only it could rev
Posted 27 April 2010 - 12:53 PM
Posted 27 April 2010 - 12:55 PM
Why do you need to ask. Everyone knows what you should be doing to N/A's and it's got nothing to do with turbos. Z22SE all the way. So many parts available so easily.
There is also a VX with a 2.4L engine conversion which has the variable valve timing head.
Posted 27 April 2010 - 01:02 PM
Posted 27 April 2010 - 01:51 PM
Yep, that's me. The 2.4L engine just bolts in too, although you'd probably have troubles with the ECU unless you go standalone.
However it turns out I can't find the standard maps for the cam phases anywhere (and the ones for the turbo aren't the best), so if you go for a standalone ECU you're looking at spending a lot of time trying to map the engine for the best performance - and even then you're not getting anywhere near Turbo/SC power
However, you could go nuts and have a supercharged 2.4 like has been done in the states
Posted 27 April 2010 - 04:51 PM
Posted 27 April 2010 - 07:34 PM
Posted 27 April 2010 - 10:01 PM
380bhp will soon be the norm with a Harrop sc fitted to the z22se
Yes please!
Posted 27 April 2010 - 10:04 PM
Just change the bellhousing
You're a bellhousing!!!
Posted 27 April 2010 - 10:09 PM
to be collected tonight from me9 9ps
Yes please!
Posted 28 April 2010 - 02:55 PM
Posted 28 April 2010 - 04:10 PM
Posted 28 April 2010 - 04:51 PM
Pm John Faulkner as he has done it. Are you wanting to use the LEH 6 speed box though or the LET 5 speed as both will have different costs attatched
I was thinking that I would use the F23, as I wrongly thought that was what was already fitted to the NA - however, if that's not the case I guess it's a good excuse to upgrade to the M32 6 speed
Thanks for the tip - I'll PM John!
Posted 28 April 2010 - 05:02 PM
