You do notice it. 7% is quite a lot especially in a car where you can detect if you've lost 2 PSI from your tyre.
The weight shows itself at that moment of turn in. The NA is a lot crisper on turn in. Not a big deal for many but the NA has always had the slight handling edge. with the charger it can also match the speed now.
Thanks.
Saw your write up on PH too BTW.
The wheel widths are also quite narrow? My car wheels are 8.5J as standard...
Can the VX accomodate larger/wider wheels?
You can run rears on the front but I wouldn't say you'd need to. That car has an inherent balance to it. People complain of understeer but in my experience it depends how your driving the car. If you drive it bearing in mind where the weight is distributed it will never under steer. Slow in fast out. Of course with the charger any understeer can just be dialled out with a jab of the throttle
Another benefit to the SC over high powered turbos is that the linear power delivery is safer and more useable. The turbo will feel a lot faster for sure but for me personally the VX is all about maximising how quickly you can drive down a typical B road. In real terms there wont be a lot in it between a Turbo and NA but the NA driver will be having more fun
