Turbo Trouble!
Posted 26 May 2010 - 09:06 PM
Posted 26 May 2010 - 09:23 PM
Posted 26 May 2010 - 09:29 PM
Posted 26 May 2010 - 09:33 PM
Courtenay offer the pipe i've just bought - LINKY
Also, here is a LINK to my post (with video) so that you can see if the noise is similar to your own.
A-GAME is off to Back on Track in a few weeks so we shall await the outcome of that and see if there are any more suggestions.
In the mean time I am trying to find a time when I can take off the undertray to check all my boost pipes for splits or to see if they have popped off - i'd imagine split if anything as my noise only appears once the engine is warmed up!
Posted 27 May 2010 - 07:39 AM
VXTyrant, are you still running a std turbo at the moment? Not stage 2 yet is it? If so that's interesting to see that the hose can collapse even on standard map. I had a big power dip at 4k revs which I put down to the same problem, but I reset my ECU the other day and that seemed to fix it. Maybe it's only a temporary fix though, I've yet to see.This was solved by test-fitting redvts' pro-alloy pipe to mine last week.
Posted 27 May 2010 - 08:01 AM
Yeah just a lightly modded standard VXT at the mo. Done a few induction mods so air will be getting sucked through there alot faster than a standard VX so maybes that's the reason why I guess
Posted 27 May 2010 - 08:03 AM
Sounds similar to an issue both A-GAME and I are having with our tubby's at the moment. We are getting a 'fluttering' noise but my drop in power is only slight and seems to appear between 4-5,000 revs in 3rd and 4th gear. This was solved by test-fitting redvts' pro-alloy pipe to mine last week. So i've ordered my own pro-alloy pipe (in stealth black with red pipes
Cheers for the advice, although my symptoms are a bit different. When I first drove the car there didn't appear to be any real lag, obviously there was still the flat spot between 2-3k revs, but now it just seems like the turbo isn't spinning up very quickly, and when you come off the throttle it almost sounds like someone has fitted a dump valve to it!! I live in the North East too, so if yo're free anytime, i'll come down for a drive?
Thanks again
Posted 27 May 2010 - 12:22 PM
I would have thought airbox mods would help if anything because it would reduce the vacuum pressure and potential collapse...might be wrong. Just wondered because mine is only a stage 1 (and a bit) but I seem(ed) to be getting the same effect.Yeah just a lightly modded standard VXT at the mo. Done a few induction mods so air will be getting sucked through there alot faster than a standard VX so maybes that's the reason why I guess
Posted 27 May 2010 - 01:54 PM
sounds like recirc is split to meCheers for the advice, although my symptoms are a bit different. When I first drove the car there didn't appear to be any real lag, obviously there was still the flat spot between 2-3k revs, but now it just seems like the turbo isn't spinning up very quickly, and when you come off the throttle it almost sounds like someone has fitted a dump valve to it!! I live in the North East too, so if yo're free anytime, i'll come down for a drive?
Thanks again
Posted 27 May 2010 - 03:38 PM
Edited by VXTyrant, 27 May 2010 - 03:49 PM.
Posted 27 May 2010 - 06:13 PM
Posted 28 May 2010 - 06:53 PM
Posted 28 May 2010 - 07:04 PM
Edited by JohnTurbo, 28 May 2010 - 07:05 PM.
Posted 28 May 2010 - 08:31 PM
The only day I'm ever free is Fridays mate. I may be cycling next fri unless the weather is awful. Could meet up on an evening (6pm onwards, mon, tue or thu) Based on the description john turbo just gave I'd look at replacing the re-circ valve asap to avoid any fatal damage!VXTyrant - Thanks very much mate, i'll be free sometime next week if you're about. It's sounding more like the recirc valve, but would be good to meet up so you can hear the turkey!! Does that mean i'll have to wash the car though....
Posted 29 May 2010 - 09:34 AM
Posted 29 May 2010 - 11:25 AM
Lots of people use AET Turbos in Yorkshire, not sure how much it costs but they can recondition/repair and even turn it into a 'hybrid' turbo that can be used to tune to stage 4 iircdo you know how much it is to recondition a turbo?
Also, I've heard nothing but good things about them. That's where I'll be taking mine when planning on the stage 2-4
AET's number: 01924894171
AET's website: http://www.aet-turbos.co.uk/
Posted 29 May 2010 - 02:10 PM
Posted 29 May 2010 - 02:14 PM
Posted 29 May 2010 - 03:19 PM
Edited by JohnTurbo, 29 May 2010 - 03:22 PM.
Posted 29 May 2010 - 05:10 PM
Zoobeef makes a good point that the small vac line which connects to the valve should be checked.
As for re-conning your turbo - don't worry too much. Yes compressor surge will speed up the death of your turbo, but only like smoking will speed up your death! A short stint shouldn't have caused any noticeable harm. - In fact some turbo systems don't recirculate at all, especially on diesels.
The boost control solenoid points are interesting. Potentially there are two modes of failure:-
1) solenoid fails open, car runs boost equal only to the wastegate spring force = slow!
2) Solenoid fails closed, car overboosts. Typically i'd expect the ignition to retard, giving a noticable jerk.
(Note it shouldn't be the solenoid affecting the OP's problem)
Edit:-
Actually when the spring alone is used to control boost there is a flutter, i'm just surprised the drop in power is only slight. Must be a stiffish spring.
Thanks again JohnTurbo, I took the car along to a lotus specialist, which in retrospect maybe wasn't the best option since I needed the engine not chassis looked at!! Either way, he ran a diagnostic check and no errors came back, is this in line with the recirc theory, as he did mention a possible electrical fault and mentioned the solenoid? The symptoms are definately more like the recirc valve you talked about though.
