Cv Boots
40 replies to this topic
#1 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 June 2010 - 09:40 AM
I am trying to source some CV boots for the inner CV joint on the VX, will buy a box full if I can find out the dimensions. Can anybody give me the shaft diameter, the CV diameter and the boot length?
#2 techieboy
Posted 22 June 2010 - 09:41 AM
Will dig my spare out at lunch time and break out the calipers and rulers. thumbsup
#3 siztenboots
Posted 22 June 2010 - 09:43 AM
is the F23 mounted at a different angle/position on the 2.2 , just trying to understand why failures seem more common on that variant. Passenger side go more often?
Edited by siztenboots, 22 June 2010 - 09:44 AM.
#4 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 June 2010 - 09:44 AM
Thanks.
I am looking at getting a supply of these as there always seems to be confusion when needing to fit one.
I have a complete driveshaft arriving tomorrow and will swap over at the weekend, let me know if you want me to fit yours as well?
#5 techieboy
Posted 22 June 2010 - 09:48 AM
Thanks Mike, might take you up on that offer. thumbsup
#6 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 June 2010 - 11:01 AM
That is where the exhaust bend is and the heat there is much higher than the drivers side. It is also why the passenger rear calliper and shock also wear quicker.
#7 techieboy
Posted 22 June 2010 - 11:34 AM
The OEM inboard boot is manufactured by NTN and has what might be a part number/size code of 17-73#BJ100. That might imply a 73mm nominal diameter at the thick end which is quite a way short of the 88.2mm I measured. Can't remember if there was a step down in the size of the CV joint where the boot is strapped on but don't think so.
The outboard joint is again from NTN (as are the joints by the look of them) and has a part number of 340-100, I think.
NTN are Japanese so possible they might be fitted to a Ricer. :unsure:
Edited by techieboy, 22 June 2010 - 11:36 AM.
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 June 2010 - 11:43 AM
Thanks Matt, that is a comprehensive answer. I have sent the details off and await a response.
#9 techieboy
Posted 22 June 2010 - 11:45 AM
thumbsup Would be good if we could track down a non-Vauxhall source as their prices are a fecking rip-off and they were on back order when I tried to get one last year.
#10 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 June 2010 - 12:36 PM
thumbsup
Could you please do the same for the outer boot, I have found a supplier and getting a couple of samples down.
Will be much cheaper than the Vauxfruad ones
#11 Scotsdave
Scotsdave
  • 761 posts
  • Interests:Muff diving
Posted 22 June 2010 - 01:09 PM
Did someone not post in an earlier thread that the boots were off of some sort of Honda?
#12 BRG_Pete
BRG_Pete
  • 285 posts
Posted 22 June 2010 - 01:13 PM
M3KDJ posted the following on this thread
Dont know if its any help but had a look on our parts system this morning...
9197858 is the GM number - not the same as any other GM boot kit. Aftermarket wise you will need a Quinton Hazell part number QJB1033 or equivalent.
If it helps its also the same as a Honda NSX (42017-SL0-000) or a Kia Sedona (0 K55 22 2540).
Sadly we dont keep them in stock....
If you are after a universal one the sizes needed are 25mm shaft size, 87mm joint size with an overall length of 96mm.
Good luck with your search!
Kevin
Edited by BRG_Pete, 22 June 2010 - 01:14 PM.
#13 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 June 2010 - 01:57 PM
Kevin
I have tracked down the inner already, just need dimensions on the outer if you have them Kevin.
9197864 is the part number outer and Vauxhall price is £57 plus the VAT
#14 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 12 August 2010 - 02:49 PM
My inner near side CV boot has got a split in it :( What did we resolve from this? Are the Kia ones cheaper and the same? Cheers chinky chinky
#15 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 August 2010 - 02:54 PM
just pm chinky chinky
#16 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 12 August 2010 - 03:41 PM
Is Mushroom Racing supplying these yet, my n/s inner went yesterday (again).
#17 slindborg
Posted 12 August 2010 - 03:44 PM
vicous rumour suggests the inners are sh**.....
#18 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 12 August 2010 - 03:45 PM
Fab, did you use the Kia or Honda ones? or did you use the aftermarket ones?
Clifie isnt supplying them any more due to quality issues he is looking into thumbsup
#19 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 August 2010 - 03:46 PM
B) replaced mine with the original one :P on business :D
#20 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 12 August 2010 - 03:59 PM
Cheers thumbsup
