Which Cone Filter Is Best
84 replies to this topic
#1 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 04 July 2010 - 10:06 AM
My air filter is bad I have replaced it with a temporary cone filter but would like to get one which is designed for high BHP any links or suggestions welcome. Think Lee mentiones cosworth ones
I have always been happy with K&N onesK&N filter
#2 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 04 July 2010 - 10:09 AM
I got a massive cone filter from CS which I've been pleased with :) Basically it is a case of the bigger the better I would imagine? :unsure: but make sure it isn't a foam one because the suck of the supercharger will pull it flat thumbsup
#3 Winstar
Winstar
  • 4,264 posts
Posted 04 July 2010 - 10:52 AM
Not really, all depends on where it's fitted ie too big and you not get good flow into it and if it's too big you'll get unwanted turbulance in the inlet, more of a problem if you runinng a AMM ;)
I've always liked the APEXI Power intakes clever design and good filtration clicky, PM duncan_VXR as I think he found a good supplier.
#4 FLD
Posted 04 July 2010 - 02:35 PM
I have a cosworth K&N filter on mine. Its a large 18"long by 10"dia at the base. Its a single cone but twin cone ones are available for stoopid power cars. I found this a comfortable fit in the VX whilst allowing good airflow to it. Cost me a tenner but I had to service it.
#5 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 04 July 2010 - 03:13 PM
Apexi. All the way. Some filters offer the same power gains, some offer the same filtration, but never both. K&N will filter coarse gravel, and that's about it. There is a good and scientific comparison available on the net if you hit Google.
#6 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 04 July 2010 - 03:18 PM
http://www.mkiv.com/...filters_test/2/
#7 markiii
markiii
  • 1,052 posts
Posted 04 July 2010 - 03:21 PM
Apexi every time
#8 VIX
VIX
  • 9,497 posts
Posted 04 July 2010 - 03:35 PM
Mine has the Jetex which I understand came with the SC. Do Harrup recommend anything? :unsure:
#9 The Batman
Posted 04 July 2010 - 04:43 PM
get a cosworth air filter thumbsup
pipercross i believe it is! the thing is bigger than my head :lol:
link
think i may order one aswell! ask for discount :lol:
Edited by joe_589, 04 July 2010 - 04:45 PM.
#10 vocky
Posted 04 July 2010 - 05:17 PM
cosworth group A K+N cone filter thumbsup
#11 siztenboots
Posted 04 July 2010 - 06:35 PM
its a bit small, got anything bigger? :)
#12 alanoo
alanoo
  • 1,324 posts
Posted 04 July 2010 - 09:07 PM
Honda S2000 OE paper filter...
#13 NickB787
NickB787
  • 7,813 posts
Posted 04 July 2010 - 09:53 PM
Interesting reading, max protection but max airflow Duncan where are you
#14 Jameshs
Jameshs
  • 3,511 posts
Posted 05 July 2010 - 07:50 AM
Apexi on mine and cant fault it
#15 NickB787
NickB787
  • 7,813 posts
Posted 05 July 2010 - 08:33 AM
Been having a good look and maybe the Apexi could be what I am after. Best place to buy Apexi then? need a 90mm adapter though, maybe even bigger with the LS4 TB :unsure:
Edited by NickB777, 05 July 2010 - 08:35 AM.
#16 james141
james141
    Whiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiine
  • 3,667 posts
Posted 05 July 2010 - 08:35 AM
#17 techieboy
Posted 05 July 2010 - 08:38 AM
Remember the Z20LET ecu conversion though. You'll be needing to accommodate an 80mm AMM somewhere between filter and throttle body. thumbsup
#18 NickB787
NickB787
  • 7,813 posts
Posted 05 July 2010 - 08:40 AM
wonder if you can write the AMM out of the ecu?
Edited by NickB777, 05 July 2010 - 08:40 AM.
#19 techieboy
Posted 05 July 2010 - 08:46 AM
I think they can write the AMM out but Jon really wants to use it as it means they will be able to map part throttle response much much better than they can with just a MAP sensor. That's one of the things he is really looking forward to as a result of the conversion. Maybe there's a 90mm Bosch one of some hyper Audi, or similar.
#20 markiii
markiii
  • 1,052 posts
Posted 05 July 2010 - 09:26 AM
can I take it from that that the Z20Let ECU can manage both AMM and MAP?
