F23 Boxes
Posted 24 September 2010 - 08:08 AM
Posted 24 September 2010 - 08:10 AM
Posted 24 September 2010 - 08:14 AM
Final drive ratio is definitely different between turbo and NA. Not sure if there are other physical differences like starter motor position?
starter motor is on the inlet side on a turbo.
Posted 24 September 2010 - 08:21 AM
Edited by jbudgie, 24 September 2010 - 08:22 AM.
Posted 24 September 2010 - 08:27 AM
Posted 24 September 2010 - 08:33 AM
Posted 24 September 2010 - 08:37 AM
Posted 24 September 2010 - 08:42 AM
If starter motor is on different side, from which car can I source a box for a tubby?
Dont suppose it would matter about the final drive ratio would it?
Final drive ratio is important as it will affect top speed, acceleration & revs.
Higher final drive ratio = lower top speed with faster acceleration, but will be revving higher at same speed so if you do a lot of motorway miles it will not be as quiet or fuel friendly.
Not sure what the factory f23 final drive in a vxt is but if I was having a gearbox rebuild I'd do what I did on my last car & go with higher ratio as top speed & motorway cruising not that important to me.
I went from 3.8 to 4.2 & was pleased with results.
Cheers
Posted 24 September 2010 - 08:47 AM
Cheers
generally if you get a diesel box then ratios will be much longer to suit the 2000 rpm range. In terms of different clusters then there is a nice Alfa JTS 5 speed setup that is very nice and close , especially 3rd 4th.
Edited by siztenboots, 24 September 2010 - 08:49 AM.
Posted 24 September 2010 - 08:51 AM
Posted 24 September 2010 - 08:56 AM
Turbo final drive = 3.65 (Ident Code AF)
NA final drive = 3.95 (Ident code TN)
sticker on mine says F23TR
Gearbox ---- Engine/model -------- Final Ratio
F23SC X20XEV 3.95
F23TS X20XER 3.95
F23SH X20XEV 3.74
F23SD X20XEV 5Dr hatch 4.17
F23TR Z20LET coupe 3.63
F23DZ Z20LET Zaffira 3.95
F23SF Z22SE ALL (not Zaf) 3.9599
F23SG Z22SE Zaffira 4.17
F23SB Y20DTH ALL (not Zaf) 3.63
F23SA X20DTL ALL (not Zaf) 3.84
F23SJ X20DTL/Y20DTH Zaffira 4.17
Edited by siztenboots, 24 September 2010 - 08:58 AM.
Posted 24 September 2010 - 01:24 PM
Posted 24 September 2010 - 01:45 PM
Edited by siztenboots, 24 September 2010 - 02:00 PM.
Posted 24 September 2010 - 06:33 PM
Edited by jbudgie, 24 September 2010 - 06:34 PM.
Posted 02 October 2010 - 03:56 PM
Posted 02 October 2010 - 04:02 PM
That's the ident code of the gearbox and is the correct version for the turbo, according to the EPC. As pet my earlier post.There is a paper sticker with a number then the letters 'AF'
Does this mean anything ?
Posted 02 October 2010 - 04:34 PM
