Alcantara - How To Fit It?
26 replies to this topic
#21 fred666
fred666
    All Show, All Go
  • 2,291 posts
Posted 06 February 2011 - 01:52 PM
You'll need to creat an account on www.photobucket.com
Its pretty easy then though, you can upload thousands of pics and you copy the [img] tag of the pic when you post and the pic will appear :)
#22 ghand
ghand
    Drunken lampposts only
  • 9,215 posts
    Oh and more whisky
Posted 06 February 2011 - 01:56 PM
Thanks ,will do that (well try!)
#23 ferg
ferg
  • 422 posts
Posted 03 March 2011 - 09:16 PM
Yes, it really has taken me this long to build up courage to do the first doorcard, but here“'s the result:
The sharper eyed amongst you might spot a couple of "bubbles" in the most concave parts of the door pull, and around the window winder, but after fitting, they're not noticeable at all. Maybe the next one will be better, and maybe this one will deteriorate after a while, but for the time being I'm very satisfied with the result.
After spending ages thinking out all sorts of complicated "smart" ways, I finally did it in the simplest way imaginable. Because I never actually managed to find a description of how to fit the Alcantara, here's mine. Hopefully others with more experience than myself will be prompted to contribute with alternative suggestions and hopefully this will help others that are don't know where to start. No pictures though - it's kind of difficult to take pictures when you only have two sticky hands and you're trying to finish as quickly as possible before the glue dries.
0.1- I passed on the "3M 90" spray glue - it costs GBP 40 over here. At that price I'd rather take a chance on having to do the whole lot over again.
0.2- I didn't remove the silver paint first as it didn't seem to react to the glue, but it really seems stupid not to, so I probably will next time. Paint stripper, then roughening up the surface slightly with sandpaper sounds like a good idea.
1- After cutting out the material I spent some time stretching the area where the door pull would be. I did this by (difficult to explain this..) holding the ends of my thumbs together on the one side, then gripping the material and "bending" it over. It didn't seem to be close to getting torn. The result was a very "saggy" area, indicating that this really helps. Next time I'll stretch the fabric even more in that area, and maybe a little in the window winder area.
2- Spray the glue evenly over the correct :rolleyes: side of the Alcantara.
3- Spray the rear of the door card around the edges, and around the window winder hole (I covered the velcro fasteners with gaffa tape first).
4- Turn it over and spray an even, not too thick, coat over the entire front surface of the door card (I think I might have had too much in the concave areas of the door pull and window winder.
5- Wait as long as it takes for the glue on the front surface to become tacky. At 0C in the garage, this took quite a while. I suspect that this is *THE* most important part of the whole process.
6- Lay the door card gently on to the Alcantara in exactly the correct position - first time. You will have cut it about 2cm. oversize, so this is not difficult.
7- Turn it over and start pressing the Alcantara into the door pull first. Take care that wrinkles don't appear on the rest of the card surface.
8- Once the door pull is done, the rest is easy, but should probably be done as quickly as possible before the glue dries too much. Not sure how long that would be though. Smooth out the front carefully, avoiding wrinkles and bubbles.
9- Lastly, turn it over and fold over the edges, cutting out the extra material at the corners with scissors, and cutting the window winder hole into segments with a sharp knife.
10- I used some strong clips to press and hold a thick piece of rubber into the door pull part to try to prevent the material from loosening while the glue set. I believe this helped. Didn't bother with clips anywhere else though.
HTH!
#24 fred666
fred666
    All Show, All Go
  • 2,291 posts
Posted 03 March 2011 - 09:27 PM
top job chinky chinky Had very similar in my astra :)
#25 Ben NA
Ben NA
  • 480 posts
Posted 03 March 2011 - 09:39 PM
Looks great and good instructions to go with it! Top job chinky chinky I still haven't tried taking my door cards off. I alcantara'd my dash plates about 3 months ago!
#26 Darcini
Darcini
  • 2,508 posts
Posted 03 March 2011 - 10:01 PM
If it's genuine Alcantara fabric you are using there are two kinds, one has a backing which is used for hard wearing applications like upholstery, and an un- backed version which is exactly the same but without the backing so therefore stretches more, suitable for trimming panels/dashboards etc. If you have the backed version with a bit of patience you can peel off the scrim backing which will then allow the fabric to stretch and form around curves much easier. It' been said many times before, but don't waste money on cheaper faux suede fabrics, they will fade very quickly in sunlight. They look really good jobs thumbsup
#27 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 03 March 2011 - 10:17 PM
I put a couple of stitched lines on mine.
Not a very good picture:
