Abs Removal?
Posted 25 February 2011 - 08:14 PM
Posted 25 February 2011 - 08:17 PM
Posted 25 February 2011 - 08:19 PM
If you don't want to use it fit a kill switch
the purpose of removing it is saving some weight.
Posted 25 February 2011 - 08:29 PM
Posted 25 February 2011 - 09:45 PM
Posted 26 February 2011 - 04:37 AM
No way! Add a dot 'cause 3.0kg are more likely to gain. The ECU and the hydraulics are the only weight you may gain, it's only a very small part of electromechanic. You will never recognize the loss of weight in matter of performance.the weight savings were more than 30kg, i think.
The ABS delivers the speedo signal, so by removing the ECU you will need to generate a new speedo signal. You have a degree in electronics? Then go on, develop some electronics, build it up, drop it in, see if it works.
Sorry, a kill switch for trackday use or swap in the Elise ECU (which is the best option imho, this little thing gives you ABS performance you will not miss).
Edited by cs_, 26 February 2011 - 04:37 AM.
Posted 26 February 2011 - 09:48 AM
Posted 26 February 2011 - 10:22 AM
Posted 26 February 2011 - 11:52 AM
Plus you need ABS for MOT unless you have a friendly mechanic doing it. AS said above best to just fit a kill switch
Thats not quite true, if you have ABS on the car then it will be tested via the light going out on the dash within a certain amount of time after starting the car.
If you take the ABS of the car then there is nothing to test in the same way as changing to a non airbag steering wheel, although MOT reg,s are going to get very strict soon as to what you can or carnt change (on modern cars atleast) thanks to the interfering euros =]
Sam.
Posted 26 February 2011 - 01:48 PM
Posted 26 February 2011 - 01:54 PM
There should be a rubber lined P clip on each wishbone to hold the brake line. I replaced mine when I refreshed the suspension and think I used 8mm clips.
Posted 26 February 2011 - 02:06 PM
I think this is the page which i saw. He says that was about 25lb (not kilos
), the difference was noticeable and "is clearly a worthwhile conversion" but there is a problem "The only thing that is problem with the installation right now is that the hoses at the wheels don't have anchor fittings in place to attach them to the struts. I was able to rig them with zip-ties and some anti-chaffe tape, but I suspect that some wear will occur and I'll have to keep checking on the lines if I don't want to rocket off the edge of a curve at a most unexpected moment!". who knows...
edit: link
http://www.kipanders.../rs/abs_rem.htm
http://www.google.gr...8&q=abs removal
Edited by Psychopathis, 26 February 2011 - 02:08 PM.
Posted 26 February 2011 - 02:10 PM
Posted 26 February 2011 - 05:00 PM
Posted 26 February 2011 - 05:18 PM
Posted 26 February 2011 - 05:20 PM
If you remove your ABS try insuring you car with it as a declared mod, I wish you the very best of luck but AFAIK there is not a single company that will cover you.
Bet a sensible insurance sompany wouldnt really give a fcuk.... MANY non abs cars about
Posted 26 February 2011 - 05:22 PM
But i cant help wonder (please dont
"Servo-assisted ABS brakes were ruled out as they would imply increased mass, complexity and reduced brake feel; however at the cost of increasing the required skill of the driver."
Edited by Psychopathis, 26 February 2011 - 05:34 PM.
Posted 26 February 2011 - 05:23 PM
Posted 26 February 2011 - 05:27 PM
thank techieboy for the responces
But i cant help wonder (please dontme) why this feature was left out of the legendary mclaren. Since its so light in the speedster, mclaren wouldnt have a problem with all those advanced materials that uses...
What it probably meant was they didnt want to spend the money/time with Botch Motorsport division to get the ABS working right.
Thats what you get for a cheap car
Posted 26 February 2011 - 05:28 PM
